Public Pool remember BTC address
Hi All,
I have Public Pool setup with my two BitAxe miners to my Knots node and all is working well. In fact both miners are hitting much higher difficultly levels than they did with CKPool. Every time I open the Public Pool app I have to re-enter my BTC address to check the stats in the app. Is there a way for Public Pool to remember my BTC address?
Cheers
I agree, it is a pain.
Hey @IndoPilot, @stinger32!
So try enabling browser cookies. On my setup that keeps the BTC address saved so I do not have to re enter it every time :flexed_biceps:
Bookmarking it should work since that is a GET and not a POST
These seem like they would work, but should I have to? The shortcut is on the desktop to be clicked.
But web browser you are using?
firefox
after submitting the receive address and going to the details page, bookmark it.
Thank you for this, but the question is whether I should have to do it. I do not check it enough to be concerned with this workaround. When I do want to see, I log into the miner and copy the wallet.
Again, thank you for your help.
The session cookie only last so long. So I don’t really consider it a work around.
