my store has Version1820d8d1.
This is not the latest I suppose…
Changing the umbrel:local:2018 to the IP of the Umbrel and opening port 2018 on my router seemed to fix the issue for me.
hello guys, i have the same problem i cant connect to my node pool. any suggestions? what kind of directions did you give? as a device i have an avalon nano 3
as pool version 9c14003
node bitcoin version 28.0
You have to set as pool something like that
stratum+tcp://192.168.178.150:2018
Thanks, that solved the problem <3
similar issue… I am trying to point an S9 that is using HiveOS firmware. I tried the IP address but unfortunately didn’t work. Surely its user error on my part any suggestions would be much appreciated.
Anyone have more infos regarding Nano 3 dropping out of Umbrel Public Pool ?
My Nano 3 connects just fine and hashes for a couple minutes, then drops out to backup pool.
Wroks with IP setting : stratum+tcp://192.141.0.132:2018
Umbrel Public Pool Version : 9c14003-w (latest)
Current Nano 3 Firmware Version : 24032701_48bd3a6
Could anyone recommend how to update Nano 3 Firmware or can point me to a .BIN file ?.. The option is no longer avail in App or Website nor FMS : Manufacturer seems to have removed any possibility :-/ but it “Upgrade” still exists in Webpage.
Stopped using Public Pool some time ago so I can’t help you with that, but DATUM works really well, using it for months now with Nano 3 and other miners, you can try with that one, just giving you an option.
