I install public pool i have 4 bitaxe one avalon , avalon no cente my pool in my node but my bitaxe work good
Are you saying the Avalon does not show up on the public pool? If you got the 4 Bitaxe to connect then something is wrong in the Avalon configuration.
My bitaxe is fine but avalon no connected I don’t what’s happen !
On the Avalon, is there a toggle for solo mining?
on my nano3 only ip address worked. umbrel.local didn’t
Yes thanks that’s i use ip address now works ![]()
