Problems with connecting to bitfeed and bitcoin RPC explorer.
  1. My network environment
    optical cable - wifi machine - lan cable (wired) full node (umbrel)
  2. Problem
    Bitfeed, etc. cannot be accessed. It’s probably a proxy or firewall issue. Bitcoin full node and Mempool Electra are all operating normally.
It just keeps saying starting. To solve this problem, I rebooted several times and changed settings, but it didn’t work.
Are there any similar cases?
I found that bitfeed conflicted with my bitcoin node. In my case, bitfeed ran but my node couldn’t be reached. After I uninstalled bitfeed, it worked again.
Thank you for your reply. I solved the problem by completely reinstalling ubuntu and umbrel.
