Hey there,
My node runs fine, but sometimes, when I try to open it again, I will get stuck on the page below.
I don’t know if it’s a faulty SSD or what else it might be. The node’s been running for less than a month, so I’m guessing it might be an SSD or power source fault. I got all the items from Umbrel’s recommended list.
It has worked in the past to turn off the Raspberry Pi, switch the USB port, and turn it back on again, but not always.
Thanks so much for the help in advance!
edit: It’s not on start-up that this happens. I can be using the node, take a break, then after an hour when trying to use it again, run into this error.
Thanks!
