Plex refuses to uninstall
I’m trying to uninstall Plex, but the app refuses to leave and is stuck at “starting”. Any tip appreciated. Thanks.
Hi @carloskruz, please try the following.
SSH into your Umbrel
and then run the following script
sudo ~/umbrel/scripts/app uninstall plex
Let me know if there’s any further issues!
Hi @smolgrrr , thank you for your prompt response. I followed the steps but got the following message:
“Removing images for app plex…
ERROR: The Compose file ‘/home/umbrel/umbrel/app-data/plex/docker-compose.yml’ is invalid because:
services.server.environment contains non-unique items, please remove duplicates from [‘PUID=1000’, ‘PGID=1000’, ‘VERSION=docker’, ‘PLEX_CLAIM=claim-_oxdLuRF7GwB_yYoaUG8’, ‘PLEX_CLAIM=claim-_oxdLuRF7GwB_yYoaUG8’, ‘PLEX_CLAIM=claim-zuezfemDyKzJhGSR-VKWclaim-7FP2ZzajE1r7Cbb-egaY’]”
Any idea what it means? Thanks in advance!
Managed to unistall. Used the command line to install plex and unistall it after:
  1. On Windows, open Command Prompt
  2. Type: ssh -t umbrel@umbrel.local
  3. Enter password
  4. Type: sudo ~/umbrel/scripts/app install plex
    5 Type: sudo ~/umbrel/scripts/app uninstall plex
Plex gone!
Thanks for letting us know the step you took to get it working and the output you had, really helps, let us know if you had any other questions!
