Paperless-ngx broke with latest update
I have had Paperless-ngx running on UmbrelOS 1.5 for some time. I attempted to install the latest update for Paperless-ngx (2.20.5). The update failed to complete, after which the app was no longer usable. I attempted to uninstall and re-install Paperless-ngx and it would not install. Then I spun up a new image of UmbrelOS 1.5 and tried to install Paperless-ngx on a “fresh” UmbrelOS, and that also failed. There were no error messages at any point. It appears the latest release of Paperless-ngx is not installable on UmbrelOS.
Any help would be appreciated!
If this forum is not appropriate for this problem, please let me know if there is a better place to submit this error.
If Paperless-ngx is not giving any logs … then, they must be going to the System logs.
In Umbrel, goto Settings, Troubleshoot, umbrelOS
The errors that Paperless-ngx is giving, should be in that log.
Thanks for your quick response! Here is the log from the install attempt for Paperless-ngx:
Jan 28 21:13:06 umbrel umbreld[1202]: [apps ] Installing app paperless
Jan 28 21:13:06 umbrel umbreld[1202]: [apps ] Setting up data directory for paperless
Jan 28 21:13:06 umbrel umbreld[48207]: time=“2026-01-28T21:13:06Z” level=warning msg=“/opt/umbreld/source/modules/apps/legacy-compat/docker-compose.yml: the attribute version is obsolete, it will be ignored, please remove it to avoid potential confusion”
Jan 28 21:13:06 umbrel umbreld[48207]: Container tor_proxy Running
Jan 28 21:13:06 umbrel umbreld[48207]: Container auth Running
Jan 28 21:13:06 umbrel dockerd[829]: time=“2026-01-28T21:13:06.906143642Z” level=warning msg="reference for unknown type: " digest=“sha256:59521628c3b4aa4e37c976924f74c30e507acd89eea2dbc74f13f0354159f536” remote=“ghcr.io/paperless-ngx/paperless-ngx@sha256:59521628c3b4aa4e37c976924f74c30e507acd89eea2dbc74f13f0354159f536
Jan 28 21:13:07 umbrel dockerd[829]: time=“2026-01-28T21:13:07.231661929Z” level=info msg=“Attempting next endpoint for pull after error: manifest unknown”
Jan 28 21:13:07 umbrel umbreld[1202]: [apps ] [error] Failed to install app paperless
Jan 28 21:13:07 umbrel umbreld[1202]: Error: (HTTP code 404) unexpected - manifest unknown
Jan 28 21:13:07 umbrel umbreld[1202]: at /opt/umbreld/node_modules/docker-modem/lib/modem.js:382:17
Jan 28 21:13:07 umbrel umbreld[1202]: at handler (/opt/umbreld/node_modules/docker-modem/lib/modem.js:425:11)
Jan 28 21:13:07 umbrel umbreld[1202]: at IncomingMessage. (/opt/umbreld/node_modules/docker-modem/lib/modem.js:414:9)
Jan 28 21:13:07 umbrel umbreld[1202]: at IncomingMessage.emit (node:events:536:35)
Jan 28 21:13:07 umbrel umbreld[1202]: at IncomingMessage.emit (node:domain:489:12)
Jan 28 21:13:07 umbrel umbreld[1202]: at endReadableNT (node:internal/streams/readable:1698:12)
Jan 28 21:13:07 umbrel umbreld[1202]: at process.processTicksAndRejections (node:internal/process/task_queues:90:21) {
Jan 28 21:13:07 umbrel umbreld[1202]: reason: undefined,
Jan 28 21:13:07 umbrel umbreld[1202]: statusCode: 404,
Jan 28 21:13:07 umbrel umbreld[1202]: json: null
Jan 28 21:13:07 umbrel umbreld[1202]: }
I have installed a couple of other apps successfully so this seems to only be an issue with Paperless-ngx.
I’m no Docker expert so most of this is not familiar to me. Any help you can offer will be appreciated!
Looks to me it is having problems finding the Docker Image!
Where are you trying to install this from or what instructions are you trying to follow?
I am attempting to install directly from the “app store” in umbrel, using the blue “Install” button at the top right of the Paperless-ngx page. Info section on that page shows it coming from the Paperless-ngx Community, submitted by highghlow. Nothing fancy or unusual beyond what is provided in the umbrel app-store…
I have installed Homebox and Technitium DNS using exactly the same method and they worked fine…
umbrel@umbrel M45Core:~/umbrel/app-data/paperless$ # This forces Docker to re-verify the digests
sudo -E docker compose pull
[+] Pulling 6/6
:check_mark: tika Pulled 0.3s
:check_mark: broker Pulled 0.3s
✘ webserver Error manifest unknown 0.7s
:check_mark: gotenberg Pulled 0.3s
:check_mark: db Pulled 0.3s
! app_proxy Interrupted 0.7s
Error response from daemon: manifest unknown
So, the manifest error is on the Webserver Docker Image. The image was probably updated and now the docker-compose.yml file is out of date.
Hopefully, you can do Unix CLI Commands … ssh into your umbrelOS …
cd ~/umbrel/app-data/paperless
Run this command to remove the hash data check to pull the current docker images:
$ sed -i ‘s/@sha256:[a-z0-9]*//g’ docker-compose.yml
Don’t run this command … let the Umbrel do it but I just wanted to show that it did get the docker images:
umbrel@umbrel M45Core:~/umbrel/app-data/paperless$ sudo -E docker compose pull
[+] Pulling 43/43
:check_mark: db Pulled 14.5s
:check_mark: gotenberg Pulled 0.8s
:check_mark: app_proxy Pulled 0.8s
:check_mark: broker Pulled 11.5s
:check_mark: tika Pulled 0.8s
:check_mark: webserver Pulled 22.5s
:check_mark: tika Pulled 0.7s
umbrel@umbrel M45Core:~/umbrel/app-data/paperless$ sudo -E docker compose up -d
[+] Running 7/7
:check_mark: Network paperless_default Created 0.0s
:check_mark: Container paperless_db_1 Started 0.4s
:check_mark: Container paperless_gotenberg_1 Started 0.3s
:check_mark: Container paperless_app_proxy_1 Started 0.5s
:check_mark: Container paperless_broker_1 Started 0.3s
:check_mark: Container paperless_tika_1 Started 0.4s
:check_mark: Container paperless_webserver_1 Started
umbrel@umbrel M45Core:~/umbrel/app-data/paperless$ sudo -E docker compose ps
NAME IMAGE COMMAND SERVICE CREATED STATUS PORTS
paperless_broker_1 Docker Hub Container Image Library | App Containerization “docker-entrypoint.s…” broker 40 seconds ago Up 40 seconds 6379/tcp
paperless_db_1 Docker Hub Container Image Library | App Containerization “docker-entrypoint.s…” db 40 seconds ago Up 40 seconds 5432/tcp
paperless_gotenberg_1 docker.io/gotenberg/gotenberg:7.10 “/usr/bin/tini – go…” gotenberg 40 seconds ago Up 40 seconds 3000/tcp
paperless_tika_1 apache/tika:3.2.3.0 “/bin/sh -c 'exec ja…” tika 40 seconds ago Up 40 seconds 9998/tcp
paperless_webserver_1 Package paperless-ngx · GitHub “/init” webserver 40 seconds ago Up 39 seconds (healthy) 8000/tcp
umbrel@umbrel M45Core:~/umbrel/app-data/paperless$ ss -tulpn
Netid State Recv-Q Send-Q Local Address:Port Peer Address:Port Process
udp UNCONN 0 0 0.0.0.0:5353 0.0.0.0:*
udp UNCONN 0 0 0.0.0.0:56453 0.0.0.0:*
udp UNCONN 0 0 172.17.255.255:137 0.0.0.0:*
udp UNCONN 0 0 172.17.0.1:137 0.0.0.0:*
udp UNCONN 0 0 10.21.255.255:137 0.0.0.0:*
udp UNCONN 0 0 10.21.0.1:137 0.0.0.0:*
udp UNCONN 0 0 192.168.6.255:137 0.0.0.0:*
udp UNCONN 0 0 192.168.6.24:137 0.0.0.0:*
udp UNCONN 0 0 0.0.0.0:137 0.0.0.0:*
udp UNCONN 0 0 172.17.255.255:138 0.0.0.0:*
udp UNCONN 0 0 172.17.0.1:138 0.0.0.0:*
udp UNCONN 0 0 10.21.255.255:138 0.0.0.0:*
udp UNCONN 0 0 10.21.0.1:138 0.0.0.0:*
udp UNCONN 0 0 192.168.6.255:138 0.0.0.0:*
udp UNCONN 0 0 192.168.6.24:138 0.0.0.0:*
udp UNCONN 0 0 0.0.0.0:138 0.0.0.0:*
udp UNCONN 0 0 [::]:5353 [::]:*
udp UNCONN 0 0 [::]:44374 [::]:*
tcp LISTEN 0 128 0.0.0.0:22 0.0.0.0:*
tcp LISTEN 0 4096 0.0.0.0:2000 0.0.0.0:*
tcp LISTEN 0 128 [::]:22 [::]:*
tcp LISTEN 0 511 :80 :
tcp LISTEN 0 4096 [::]:2000 [::]:
umbrel@umbrel M45Core:~/umbrel/app-data/paperless$ sudo docker ps --format “table {{.Names}}\t{{.Ports}}”
NAMES PORTS
paperless_webserver_1 8000/tcp
paperless_broker_1 6379/tcp
paperless_gotenberg_1 3000/tcp
paperless_db_1 5432/tcp
paperless_tika_1 9998/tcp
auth 0.0.0.0:2000->2000/tcp, [::]:2000->2000/tcp
tor_proxy
So, I can manually get it to come up but I have no idea what do with this application.
Looks like the paperless UI with Port 2349 but the app did not come up.
Try looking on their Github Support Page: paperless-ngx/paperless-ngx · Discussions · GitHub
Thank you so much for your research into this failure! As I said, I am no Docker expert – that’s the reason I use a tool like umbrel…
I have an umbrel image I use for testing so I will try both the manual install and the umbrel install later today to verify.
