Hey folks - probably just a minor thing, but I currently got that blank stare and don’t see the haystack in the needle or whatever ![]()
Running Hermes Agent on Umbrel Home, connected to a local Ollama/Qwen instance on a different comp on the local network. Works.
Installed Paperclip on the same Umbrel, told it to use the local Hermes install. Fails.
“Failed to start command "hermes" in ".". Verify adapter command, working directory, and PATH (/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin).(adapter_failed)”
so… afaik the Umbrel apps sit in a tidy sandbox each - how can I convince Paperclip to use the local Hermes agent, or what would be the correct path/command?
