Please open channels:
022e5eacfe16b8db65df89d45ec7149b419867e9d58b959b390a2eaf30f69c3da6@dneenxk6flhnaloftp4tx5lruioak3alndgxojlggkzcg4v27nnqn6id.onion:9735
I want to open a 100,000 sat payment channel to someone for podcasts. Thanks
Open for 500000 sats, can you open to mine?
02d39544a0bc4104bd93916e7d16fb130483c8dddd0e9ba81550bf96561d0c9d6f@taaw2xcaprmrqh35wgxpmzgzpp3iqj2sv7qtkkysjp7hcuv2sb4ddxad.onion:9735
Done also, you are my first channel! Trying this out. My address is 022c6067d6b87f1714a4f3936e010aefacbf5c66ccd5bcb62f71095032a0dda1e5@kpbtnbbfm7ca6xkgnfcwqi5gbokbu5wv5wvlps3g3eigwlxgjxh7xxad.onion:9735
Hi there I’m trying to open a LN channel from my node to you. But every address I click on from your link gives me the message “check lightning address” and it fails to open the channel.
I’m using my umbrel lightning node.
Sorry for being a noob.
thanks
Hi @skintone,
Which software do you use for opening?
I use the lightning node app from umbrel ( called LND)
thanks for any advice
Try it with RTL. The app is also available in the Umbrel Appstore. With RTL you can first open a peer to this node. If this does not work, this node is straight offline. If you then open a peer, you can open a channel directly.
OK thanks for the advice! I’ll try that.
Rene’s suggestion is a good one. Let me know if you still can’t connect. I’ve been out of town and can’t investigate until this evening at the earliest. Sorry for the delay.
Hi there ,
Yes I still can’t connect. I clicked on the link you provided which took me to your page. But to make you a peer using RTL it requires an alias ( Node Up or Shut up) and a lightning address, which I can’t find, as everything I put in was rejected as not being a proper lightning address.
Look in 1ml.com
0303e0423fd2c40d73978b03069f63d6ca5ae1abf61f5666bbbea886181f21e8e3@fuhicgzlqp62g27nijmaloag7cnqtsmy4ifrg6q27jqi2xx3x4ccrsqd.onion:9735
Thanks Rene1980 !
that worked.
Appreciate your help!
Finally back on-site. Glad to hear that worked. That would’ve been my suggestion.
Thanks for your help @Rene1980!
Hi again Rene1980,
Regarding the RTL app, do you happen to know how to back it up? ( seed phrase etc) in case of crash?
The LND lightning app makes this seed easy to find but I cannot find anyway to do this in the RTL app.
Thanks again!
Hi @skintone,
I don’t know exactly what you mean. On the left side, under Lightning, you’ll find the option to create a backup.
Hi, I have set up my first Lightning node and would be very happy if someone would open a channel to me (Minimum Channel size 1 Mio. sats).
0279c25a1a33c537f34835550a477b15e55f3f2f582beeaefff13f000566180c5b@nbgar6s2v4vdsryofnbjvjn5vbbrqlkooalun4jc66new63zhmphz6qd.onion:9735
