Ocean Datum Setup
I’m trying to set up my node with Ocean to use DATUM with a wallet
Once you get your BTC miner set up just pull an address from you wallet, copy it in the Bitcoin Address box on the Config Tab and earnings will be sent to that address. What are you having trouble with?
It’s very easy to set up a Sparrow wallet with your node using Electrs. I have my hardware wallets connected to Sparrow so I don’t use 3rd party apps.
