Noob question about UTXOS in RTL
I got 4 UTXOS under" On-chain Transactions" in RTL, What are those, transactions that are stuck?
Where it says balances? Those are the coins in your Umbrel on chain wallet. You need those to fund channels. Those should not be stuck, you can check each address individually in mempool.space to see if they have confirmations.
Ah! Thanks, all UTXOS combined is the same as my on-chain balance.
