After upgrading to 0.4.11, I cannot login to the web portal via umbrel.local. The web login does not load, and instead loads this weird list of conflicting errors and status messages.
Oddly, it works just fine over TOR.
Any ideas?
Here are screenshots of what shows up on umbrel.local:
Sometimes it happens here, normally just reloading the page fix things.
Ah, you are correct. I thought it was the node because exiting chrome and starting it again didn’t fix, but must be chrome serves the cached version when you bring it up again. I’ll make sure to try this before posting in the future. Thanks for the help.
