Nextcloud + PhotoPrism + Jellyfin
I’m looking to setup what I think is a pretty easy system. I’ve setup parts of it before with Docker - but never got the import bits to sync.
I’d like Nextcloud, PhotoPrism and Jellyfin to all be installed. I’d like there to be a photos folder for PhotoPrism, and a Movies folder for Jellyfin inside Nextcloud.
Is this really complicated to accomplish? I’ve not found any Umbrel specific tutorials.
Did you ever figure this out?
I’m going to try this with nextcloud and photoprism this weekend BTW, will report back. looks like the photoprism docker-compose.yml will need to be significantly re-written to point to the existing mysql databse and file storage location from nextcloud. I already re-wrote the nextcloud docker-config file a bit since my data is located on a different drive than my umbrel install (intel celeron mini-pc with ubuntu)
"I’m going to try this with nextcloud and photoprism this weekend BTW, will report back. "
I hope you can find the time to report your findings. Thanks in advance.
