Nextcloud not running, please help
What can i do? This happened after upgrading to 1.4
nextcloud_app_proxy_1 | Retrying…
nextcloud_db_1 | 2025-03-09 13:42:36+00:00 [Note] [Entrypoint]: Entrypoint script for MariaDB Server 1:10.6.21+maria~ubu2004 started.
nextcloud_db_1 | 2025-03-09 13:42:59+00:00 [Note] [Entrypoint]: MariaDB upgrade not required
nextcloud_db_1 | 2025-03-09 13:42:59 0 [Note] Starting MariaDB 10.6.21-MariaDB-ubu2004 source revision 066e8d6aeabc13242193780341e0f845528105de server_uid VO55khx2FtSu+ib8LdZ5NOwgKz8= as process 1
nextcloud_db_1 | 2025-03-09 13:42:59 0 [Warning] You need to use --log-bin to make --binlog-format work.
nextcloud_db_1 | 2025-03-09 13:43:00 0 [Note] InnoDB: Compressed tables use zlib 1.2.11
nextcloud_db_1 | 2025-03-09 13:43:00 0 [Note] InnoDB: Number of pools: 1
nextcloud_db_1 | 2025-03-09 13:43:00 0 [Note] InnoDB: Using crc32 + pclmulqdq instructions
nextcloud_db_1 | 2025-03-09 13:43:00 0 [Note] mariadbd: O_TMPFILE is not supported on /tmp (disabling future attempts)
nextcloud_db_1 | 2025-03-09 13:43:00 0 [Note] InnoDB: Using Linux native AIO
nextcloud_db_1 | 2025-03-09 13:43:00 0 [Note] InnoDB: Initializing buffer pool, total size = 134217728, chunk size = 134217728
nextcloud_db_1 | 2025-03-09 13:43:00 0 [Note] InnoDB: Completed initialization of buffer pool
nextcloud_db_1 | 2025-03-09 13:43:00 0 [Note] InnoDB: Starting crash recovery from checkpoint LSN=133871166,133871166
nextcloud_db_1 | 2025-03-09 13:43:02 0 [Note] InnoDB: 128 rollback segments are active.
nextcloud_db_1 | 2025-03-09 13:43:02 0 [Note] InnoDB: Removed temporary tablespace data file: “./ibtmp1”
nextcloud_db_1 | 2025-03-09 13:43:02 0 [Note] InnoDB: Creating shared tablespace for temporary tables
nextcloud_db_1 | 2025-03-09 13:43:02 0 [Note] InnoDB: Setting file ‘./ibtmp1’ size to 12 MB. Physically writing the file full; Please wait …
nextcloud_db_1 | 2025-03-09 13:43:02 0 [Note] InnoDB: File ‘./ibtmp1’ size is now 12 MB.
nextcloud_db_1 | 2025-03-09 13:43:02 0 [Note] InnoDB: 10.6.21 started; log sequence number 133871178; transaction id 584652
nextcloud_db_1 | 2025-03-09 13:43:02 0 [Note] InnoDB: Loading buffer pool(s) from /var/lib/mysql/ib_buffer_pool
nextcloud_db_1 | 2025-03-09 13:43:02 0 [Note] Plugin ‘FEEDBACK’ is disabled.
nextcloud_db_1 | 2025-03-09 13:43:04 0 [Warning] You need to use --log-bin to make --expire-logs-days or --binlog-expire-logs-seconds work.
nextcloud_db_1 | 2025-03-09 13:43:07 0 [Note] Server socket created on IP: ‘0.0.0.0’.
nextcloud_db_1 | 2025-03-09 13:43:07 0 [Note] Server socket created on IP: ‘::’.
nextcloud_db_1 | 2025-03-09 13:43:11 0 [Warning] ‘proxies_priv’ entry ‘@% root@6309287ce868’ ignored in --skip-name-resolve mode.
nextcloud_db_1 | 2025-03-09 13:43:12 0 [Note] InnoDB: Buffer pool(s) load completed at 250309 13:43:12
nextcloud_db_1 | 2025-03-09 13:43:18 0 [Note] mariadbd: ready for connections.
nextcloud_db_1 | Version: ‘10.6.21-MariaDB-ubu2004’ socket: ‘/run/mysqld/mysqld.sock’ port: 3306 mariadb.org binary distribution
nextcloud_redis_1 | 1:C 09 Mar 2025 13:42:33.533 # oO0OoO0OoO0Oo Redis is starting oO0OoO0OoO0Oo
nextcloud_redis_1 | 1:C 09 Mar 2025 13:42:33.533 # Redis version=6.2.2, bits=64, commit=00000000, modified=0, pid=1, just started
nextcloud_redis_1 | 1:C 09 Mar 2025 13:42:33.533 # Warning: no config file specified, using the default config. In order to specify a config file use redis-server /path/to/redis.conf
nextcloud_redis_1 | 1:M 09 Mar 2025 13:42:33.534 * monotonic clock: POSIX clock_gettime
nextcloud_redis_1 | 1:M 09 Mar 2025 13:42:33.768 * Running mode=standalone, port=6379.
nextcloud_redis_1 | 1:M 09 Mar 2025 13:42:33.769 # Server initialized
nextcloud_redis_1 | 1:M 09 Mar 2025 13:42:33.769 # WARNING overcommit_memory is set to 0! Background save may fail under low memory condition. To fix this issue add ‘vm.overcommit_memory = 1’ to /etc/sysctl.conf and then reboot or run the command ‘sysctl vm.overcommit_memory=1’ for this to take effect.
nextcloud_redis_1 | 1:M 09 Mar 2025 13:42:34.097 * Loading RDB produced by version 6.2.2
nextcloud_redis_1 | 1:M 09 Mar 2025 13:42:34.097 * RDB age 10972 seconds
nextcloud_redis_1 | 1:M 09 Mar 2025 13:42:34.097 * RDB memory usage when created 0.77 Mb
nextcloud_redis_1 | 1:M 09 Mar 2025 13:42:34.097 * DB loaded from disk: 0.328 seconds
nextcloud_redis_1 | 1:M 09 Mar 2025 13:42:34.097 * Ready to accept connections
nextcloud_app_proxy_1 | Error waiting for port: “The address ‘nextcloud_web_1’ cannot be found”
this keeps on repeating…
Try restarting Nextcloud first and see if that helps. If the issue persists, check with docker ps whether the nextcloud_web_1 container is running. If it’s missing or has crashed, checking the logs with docker logs nextcloud_web_1 --tail=50 might give more insight.
