New install "Settings" not working
Brand new install onto new USB drive, as my old install failed with corrupt disk.
It boots up fine and I can install apps, however, the settings app just says “Something went wrong” which tells me nothing at all, might as well not have an error message …
Why is this so hard to get Umbrel to install?
It seems that Umbrel does not play well with the Brave browser, Chromium works fine … Suggest devs look at why this is, and maybe add some more robust web page handling. :slight_smile:
Also, just wondering if ext4 is suitable for a “server”, I would be inclined to use btrfs, at least you can do backups/snapshots. That would have saved me some data when my disk failed with ext4. Ext4 is not really suitable for SSD’s especially when you are doing constant access with Bitcoin nodes …
I’m using Brave and have no issues
Recent version?
I am running on MacOS, maybe that is the difference?
