Mathieu's Umbrel App Store — media & arr companion apps
I put together a small Umbrel community app store focused on self-hosted media tools, mostly things that round out a Sonarr / Radarr / Plex setup but aren’t in the official Umbrel App Store yet.
Apps included:
  • :stethoscope: Healarr — Scans your library for corrupt media files (ffprobe / MediaInfo / HandBrake), deletes them, and triggers a re-download through Sonarr / Radarr / Whisparr, then verifies the replacement is healthy.
  • :admission_tickets: Boxarr — Tracks the weekly box-office top 10 and syncs it with Radarr: see what’s already in your library and auto-add trending movies with smart filters.
  • :bar_chart: Tracearr — Real-time monitoring for Plex, Jellyfin & Emby (an open-source Tautulli / Jellystat alternative): stream tracking, session history with geolocation, and account-sharing detection.
  • :broom: Cleanuparr — Cleans up your download queue & disk: removes stalled/failed downloads and orphaned/unlinked files (hardlink-aware), then re-triggers a search. Works with Transmission, qBittorrent & SABnzbd.
  • :sponge: Decluttarr — Lightweight background cleaner for your *arr download queues (failed/stalled/orphaned), auto-detecting your Sonarr/Radarr API keys.
How to install:
In umbrelOS → App Store → ⋮ menu → Community App Stores → add:
Then open the Mathieu App Store and install any app.
Feedback and issues welcome!
Just added new apps and also set up Renovate and Claude to automatically update apps with a proper changelog.
That Renovate setup looks nifty. I had made a custom GitHub action that runs after Dependabot to update the version in umbrel.yaml, but yours looks a better setup as it does it all in one step. Does Github require any setup to enable Renovate? Dependabot is run by GitHub if there is a dependabot.yaml file in the repo.
Hey,
Renovate requires installing the GitHub App on your repo but it’s free for public repos. Once installed, you just add a renovate.json config file and it handles everything automatically :slight_smile:
Dependabot is cool but not very customizable.
Hi! New to Umbrel here, I’m loving the experience!
I can’t make slskd to run, it says it doesn’t have permission to write in the download folders and i can’t find the adress of those folders to chmod them.
Hello @hamiltonafjr it should be fix, can you reload the store and the re-install the app ?
Update: 14 new apps in the store
Since my first post the store has grown quite a bit, so here’s what’s new. Same install link, same idea: self-hosted media tools that round out a Sonarr / Radarr / Plex setup but aren’t in the official Umbrel App Store.
*More arrs for the stuff Sonarr and Radarr don’t cover
:books: Kapowarr — Comic book library manager. Same feel as Sonarr, but for comics: monitor volumes, grab missing issues, convert and rename files.
:open_book: Chaptarr — Ebooks and audiobooks. It’s a ground-up rework of Readarr (which upstream archived), so it’s the sanest option left if you manage a book library.
:american_football: Sportarr — A PVR for sports. Follow teams or competitions and it grabs the events for you, Sonarr-style.
Getting better files, and making them watchable
:level_slider: Profilarr — Quality profiles and custom formats for Radarr/Sonarr, managed from one place and synced from a community database. If you’ve ever hand-copied a TRaSH Guides profile, this is the app that does it for you.
:speech_balloon: Lingarr — Translates your subtitles into any language, either with a local model or an LLM of your choice.
:sponge: Sublarr — All-in-one subtitle manager: finds subtitles, and translates them with an LLM when nothing exists in your language.
:clapper_board: Trailarr — Downloads trailers for everything in your Radarr/Sonarr library, so Plex and Jellyfin have something to play on the detail page.
:repeat_button: Tdarr — Automated transcoding and library health checks. Point it at your library and it’ll normalise codecs, remux, and flag broken files. Runs standalone, no separate node needed.
Keeping the library tidy
:broom: Maintainerr — Rule-based Plex cleanup. “Delete movies nobody has watched in a year, unless they’re in this collection.” It shows you what it’s about to remove before it does it.
:light_bulb: SuggestArr — Reads your recent Plex/Jellyfin/Emby activity and auto-requests similar titles through Jellyseerr/Overseerr. Works with plain TMDb similarity, or with an LLM if you want the personalised version.
Downloading
:seedling: cross-seed — Automatically cross-seeds your existing downloads across your other trackers. Free ratio, no extra disk used (it hardlinks).
:shield: Byparr — Drop-in FlareSolverr replacement for Prowlarr/Jackett. Same API, but a modern stealth browser behind it, so it actually gets through today’s Cloudflare checks.
:musical_note: slskd — Soulseek client with a proper web UI. The place to find the rare and out-of-print music that never shows up on trackers.
:musical_notes: Soularr — Bridges the two: it takes Lidarr’s wanted list, has slskd hunt it down on Soulseek, and imports the result back into Lidarr.
Two other things
Decluttarr is gone — Cleanuparr does everything it did and more, so keeping both around was just confusing.
And everything in the store got updated today for umbrelOS 2.0: apps now declare their data root properly, so you can move an app’s data to an external drive from Settings, and pick which folder each app gets access to. That update also fixed a permissions bug where apps couldn’t write to the Downloads folder on umbrelOS 1.x — thanks to whoever reported it, that was on me.
If you had the store added already, remove and re-add it to pick up the updates straight away.
Its working now!
It’s working but wont connect to soulseek network. Where can I put my credentials?
Hello,
Sorry I never tried this integration (I don’t use it).
I pushed a fix, you can re-install the app and you can set credentials with right click on the app, settings > Advanced > Environment variables
Thanks Mathieu, it’s working fine now
Hi Mathieu!
Only could test correctly today.
It doesent complete the downloads
Hey,
Can you give me logs instead ? Thanks
Hey,
New in the Mathieu App Store: Muxarr (strip unused audio/subtitle tracks, no re-encode), Tunarr (live TV channels from your own library), NeutArr (the maintained Huntarr successor) and FreshRSS MCP (your feeds for Claude / ChatGPT).
Missing an app? Open an issue on GitHub with its name and repo. Claude packages it, tests it on a throwaway umbrelOS and opens a PR, so it usually lands in the store shortly after.
Have a nice day :slight_smile:
Question about handling a VPN / kill switch:
To my knowledge (im still pretty new to this), running a torrent client directly in Umbrel exposes your real IP to the internet. The standard fix seems to be using a VPN container like Gluetun attached specifically to the torrent client, keeping the rest of the *arr apps on the normal network.
How are you handling VPNs with this setup? Is there a simple way to wire Gluetun up with the torrent client on Umbrel so it has a working kill switch? My biggest hurddle is getting qbittorrent to not expose my IP when torrenting within umbrel.
Hello @umbrel.5nag3
In my store I developed a new app `Transmission VPN`, that use Glutten, and I’m using it with ProtonVPN and it works well :slight_smile:
Amazing… set up and working flawlessly with my SurfShark VPN. Thanks a lot Mathieu, is there anyway you can push this into the official Transmission app on the Umbrel store? Also if you could make this available for SABnzbd as well that would be perfect.
Thanks a lot, glad to hear it works with Surfshark too :slightly_smiling_face:
For the official store, I’ll take a look, but I’m not sure the Umbrel team would approve: it relies on another app (Gluetun) and it’s quite custom compared to the classic Transmission app.
For SABnzbd, I don’t use it myself, so no promise, but I keep the idea in mind.
I’ve been dreaming for ages of having a VPN app on my Umbrel with a toggle for which other apps I want to toggle to use the VPN tunnel. This is a step in that direction! I know others feel the same. Thanks again.
Thanks for the idea! A true per-app VPN toggle isn’t really doable on Umbrel: an app can’t change another app’s network.
So I made a Gluetun app on my store instead. It connects to your VPN and shares it through a password-protected HTTP proxy, so only the apps you point at it use the VPN. In Prowlarr, add it under Indexer Proxies with a vpn tag, then tag the indexers that should go through it.
If you already use Transmission VPN, create a separate WireGuard config for this one: the same key can’t be used for two connections at once.
For torrents I’m keeping Transmission VPN: a proxy can’t carry UDP or incoming peers, so a client behind it would leak and seed poorly.
It’s on the store now, I’m still testing it on my own setup. Let me know if you try it!
