How can I retrieve my history and funds with a different monero wallet
I could see funds using Tresor T on Exodus wallet but now zero balance
any help ?
Thanks
any help ?
Thanks
I have never owned a Trezor, but I see they offer a free app that works with their devices: https://trezor.io/trezor-suite
You will probably want to use that app with your device to access your funds.
I also tried the fun exercise of spinning up a VM and installing the GUI wallet from getmonero.org, and it looks like it is also be able to do what you want:
Both of those methods should work without requiring you to enter your mnemonic seed phrase anywhere, just plug in your device and authenticate.
Thank you
I have been trying to access my funs using GUI wallet but after fully syncing it shows no history
Im stock thus far
Did you use a passphrase for your Exodus wallet? Depending on the wallet architecture, a passphrase may lead to totally different addresses/keys. If a passphrase was involved, try to use the same one as before. If one was not used, then try to avoid using one with the GUI wallet.
This article offers some suggestions: https://www.exodus.com/support/en/articles/10862085-support-for-monero-xmr-has-ended There is a section specific to Trezor with another link to information on the Trezor website: Monero (XMR) on Trezor Safe Family and Trezor Model T
Maybe those can be helpful. My guess is it’s either a passphrase issue or a derivation path issue, as noted on the Trezor website. Hopefully here or maybe on Reddit or elsewhere Monero gurus might congregate, someone who has a setup like yours can offer some tips.
Thank you but still no assets
