when I type lsblk I get :
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
mmcblk0 179:0 0 59.4G 0 disk
|-mmcblk0p1 179:1 0 256M 0 part /run/rugpi/mounts/config
|-mmcblk0p2 179:2 0 128M 0 part /boot
|-mmcblk0p3 179:3 0 128M 0 part
|-mmcblk0p4 179:4 0 1K 0 part
|-mmcblk0p5 179:5 0 5G 0 part /run/rugpi/mounts/system
|-mmcblk0p6 179:6 0 5G 0 part
-mmcblk0p7 179:7 0 48.9G 0 part /mnt/root/var/log /var/log /mnt/root/var/lib/systemd/timesync /var/lib/systemd/timesync /mnt/root/var/lib/docker /var/lib/docker /home /data /run/rugpi/state /run/rugpi/mounts/data nvme0n1 259:0 0 1.8T 0 disk -nvme0n1p1 259:1 0 1.8T 0 part /mnt/root/swap
/swap
/data/umbrel-os/var/lib/docker
/var/lib/docker
/data/umbrel-os/home/umbrel/umbrel
/home/umbrel/umbrel
/mnt/root/mnt/data
/mnt/data
I’m running it on raspberry pi5 with nvme from pimo. recently flashed the SD card. using my MacBook at moment with th ssh.
any help is appreciated
