The command: Blkid:
root@umbrel:~# blkid
/dev/mmcblk0p7: LABEL=“data” UUID=“fd8ddad7-84df-428f-85cb-8e257ddce5c8” BLOCK_SIZE=“4096” TYPE=“ext4” PARTUUID=“3917b7f4-07”
/dev/mmcblk0p5: LABEL=“system-a” UUID=“c62edc3a-84ab-4446-8959-3b2a1812e470” BLOCK_SIZE=“4096” TYPE=“ext4” PARTUUID=“3917b7f4-05”
/dev/mmcblk0p1: SEC_TYPE=“msdos” LABEL_FATBOOT=“CONFIG” LABEL=“CONFIG” UUID=“BD8E-D009” BLOCK_SIZE=“512” TYPE=“vfat” PARTUUID=“3917b7f4-01”
/dev/mmcblk0p6: LABEL=“system-b” UUID=“c62edc3a-84ab-4446-8959-3b2a1812e470” BLOCK_SIZE=“4096” TYPE=“ext4” PARTUUID=“3917b7f4-06”
/dev/mmcblk0p2: SEC_TYPE=“msdos” LABEL_FATBOOT=“BOOT-A” LABEL=“BOOT-A” UUID=“BD8E-F0B7” BLOCK_SIZE=“512” TYPE=“vfat” PARTUUID=“3917b7f4-02”
/dev/sdb1: LABEL=“umbrel” UUID=“03c656f5-87fc-4477-9543-4bec49624769” BLOCK_SIZE=“4096” TYPE=“ext4” PARTLABEL=“primary” PARTUUID=“e21ffb7c-d7d0-4de8-b3c5-d39e47a0ea98”
/dev/mmcblk0p3: PARTUUID=“3917b7f4-03”
root@umbrel:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
overlay 50186784 381264 47223712 1% /
tmp 4122832 5776 4117056 1% /run
/dev/mmcblk0p7 50186784 381264 47223712 1% /run/rugpi/mounts/data
/dev/mmcblk0p5 3396844 2970688 233280 93% /run/rugpi/mounts/system
/dev/mmcblk0p1 261864 24 261840 1% /run/rugpi/mounts/config
/dev/mmcblk0p2 130796 89754 41042 69% /boot
devtmpfs 4096 0 4096 0% /dev
tmpfs 4122832 0 4122832 0% /dev/shm
tmpfs 5120 0 5120 0% /run/lock
/dev/sda1 1921694984 1031274272 792730964 57% /mnt/data
tmpfs 824560 0 824560 0% /run/user/1000
root@umbrel:~# df -h
overlay 48G 373M 46G 1% /
tmp 4.0G 5.7M 4.0G 1% /run
/dev/mmcblk0p7 48G 373M 46G 1% /run/rugpi/mounts/data
/dev/mmcblk0p5 3.3G 2.9G 228M 93% /run/rugpi/mounts/system
/dev/mmcblk0p1 256M 24K 256M 1% /run/rugpi/mounts/config
/dev/mmcblk0p2 128M 88M 41M 69% /boot
devtmpfs 4.0M 0 4.0M 0% /dev
tmpfs 4.0G 0 4.0G 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
/dev/sda1 1.8T 984G 757G 57% /mnt/data
tmpfs 806M 0 806M 0% /run/user/1000
any hope ?
