Looking for guide to transfer from SD to NVMe
Hi
I’m new here so sorry if not the right place to post.
I would like to move a functioning umbral install from SD to NVMe.
Is there a guide on how to do this please?
Thanks
I am trying to do the same, but the only guide I’ve found requires two raspberries and two disks:
It would be wonderful if someone had a lighter procedure.
Hi, you could try clonning your drive using dd if you have access to linux system. Or you could try following this guide: [GUIDE] Cloning or Migrating SSD/HDD (Windows).
Will do. Ta
