Brand new Umbrel Home. Installed bitcoin Synced and running. Installed LND. Was running. I restarted Umbrel, and LND now errors out and won’t start.
Logs are full of this error.
lightning_app_1 | E0610 00:54:50.785564211 31 ssl_transport_security.cc:1245] Handshake failed with fatal error SSL_ERROR_SSL: error:1416F086:SSL routines:tls_process_server_certificate:certificate verify failed.
Here is the log file.
umbrel_lightning_2024-06-10_10-51.log (95.6 KB)
I fixed it by deleting the tls.cert and tls.key.
I have the same error, how did you deleted the tls.cert and tls.key.? Thank you
You’ll find those files in ~/umbrel/app-data/lightning/data/lnd
Just delete the tls.cert and tls.key files you find there and then restart lnd.
Sorry for the ignorance. But how can I reach that folder? thank you
SSH into your Umbrel.
rm ~/umbrel/app-data/lightning/data/lnd/tls.crt
rm ~/umbrel/app-data/lightning/data/lnd/tls.key
Then restart lnd.
