Lightning Update
hi, did the latest update, but nothing has changed. any advise? thanks
depends what you wanna see to change.
think there was just minor improvments
you can check and compare your for example lnd version with the appstore if it’s the latest
all new features you can also see on the corresponding github page
cheers
