Lightning Terminal errors
After logging into LIT, how would I fix this?
lightning-terminal_web_1 | 2024-04-09 00:39:05.791 [ERR] LNDC: Could not receive from interceptor stream: rpc error: code = Unknown desc = permission denied
lightning-terminal_web_1 | 2024-04-09 00:39:05.791 [ERR] STAT: could not start the lit sub-server: could not start Lit: could not start litd sub-servers: rpc error: code = Unknown desc = permission denied
I am seeing the same error. If I click on add new session this error is shown in the log
2024-07-21 15:12:46.259 [INF] UNIV: Fetching 0 roots
lightning-terminal_web_1 | 2024-07-21 15:12:46.259 [INF] UNIV: Obtained 0 roots from remote Universe server
lightning-terminal_web_1 | 2024-07-21 15:12:46.259 [INF] RPCS: Starting RPC Server
lightning-terminal_web_1 | 2024-07-21 15:12:46.259 [INF] LITD: Starting LiT macaroon service
lightning-terminal_web_1 | 2024-07-21 15:12:46.259 [WRN] GRPC: [core] [Channel #26 SubChannel #27] grpc: addrConn.createTransport failed to connect to {Addr: “44.230.212.183:10029”, ServerName: “44.230.212.183:10029”, }. Err: connection error: desc = “transport: Error while dialing: dial tcp 44.230.212.183:10029: operation was canceled”
lightning-terminal_web_1 | 2024-07-21 15:12:46.373 [INF] AUTO: Starting Autopilot Client
lightning-terminal_web_1 | 2024-07-21 15:12:47.294 [INF] LITD: Starting LiT session server
lightning-terminal_web_1 | 2024-07-21 15:12:47.294 [INF] LITD: Starting LiT account service
lightning-terminal_web_1 | 2024-07-21 15:12:47.294 [INF] LITD: Starting LiT middleware manager
lightning-terminal_web_1 | 2024-07-21 15:12:47.300 [ERR] LNDC: Could not receive from interceptor stream: rpc error: code = Unknown desc = permission denied
lightning-terminal_web_1 | 2024-07-21 15:12:47.300 [ERR] STAT: could not start the lit sub-server: could not start Lit: could not start litd sub-servers: rpc error: code = Unknown desc = permission denied
I found a solution:
I think the general issue here is, that if lnd requires any new config options like rpcmiddleware.enable=true to work you will have to add these manual to your lnd.conf. Umbrel does not change your lnd.conf with any new updates. Maybe this could be added to the UI-settings?
