Hello, earlier today after updating my LND app to 0.21.4-beta, my node is stuck on starting. I tried to restart the app, restart Umbrel and it doesn’t make a difference. Umbrel didn’t lose power or anything, I just clicked update and it all went wrong.
There are some errors in the log saying: “panic: freepages: failed to get all reachable pages”. Below is an example of the error with some more info, the paragraph with error then repeats non-stop down the log.
lightning_tor_1 | Oct 12 10:24:08.000 [notice] Bootstrapped 73% (loading_descriptors): Loading relay descriptors
lightning_tor_1 | Oct 12 10:24:08.000 [notice] Bootstrapped 75% (enough_dirinfo): Loaded enough directory info to build circuits
lightning_tor_1 | Oct 12 10:24:09.000 [notice] Bootstrapped 90% (ap_handshake_done): Handshake finished with a relay to build circuits
lightning_tor_1 | Oct 12 10:24:09.000 [notice] Bootstrapped 95% (circuit_create): Establishing a Tor circuit
lightning_tor_1 | Oct 12 10:24:09.000 [notice] All current guards excluded by path restriction type 2; using an additional guard.
lightning_tor_1 | Oct 12 10:24:10.000 [notice] Bootstrapped 100% (done): Done
lightning_tor_1 | Oct 12 10:25:11.000 [notice] All current guards excluded by path restriction type 2; using an additional guard. [2 similar message(s) suppressed in last 120 seconds]
lightning_tor_1 | Oct 12 10:26:11.000 [notice] All current guards excluded by path restriction type 2; using an additional guard. [1 similar message(s) suppressed in last 60 seconds]
lightning_tor_1 | Oct 12 10:30:27.000 [notice] All current guards excluded by path restriction type 0; using an additional guard. [2 similar message(s) suppressed in last 300 seconds]
lightning_tor_1 | Oct 12 12:02:45.000 [notice] All current guards excluded by path restriction type 2; using an additional guard.
lightning_lnd_1 | 2026-10-12 15:09:34.036 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
lightning_lnd_1 | 2026-10-12 15:09:34.036 [INF] LTND: Opening the main database, this might take a few minutes...
lightning_lnd_1 | 2026-10-12 15:09:34.036 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lightning_lnd_1 | 2026-10-12 15:09:34.906 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
lightning_lnd_1 | 2026-10-12 15:09:35.921 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
lightning_lnd_1 | panic: freepages: failed to get all reachable pages (key[0]=(hex)0e59e400053e0001 on leaf page(18855) needs to be < than key of the next element in ancestor (hex)0000000000009340. Pages stack: [11500 18855])
lightning_lnd_1 |
lightning_lnd_1 | goroutine 263 [running]:
lightning_lnd_1 | go.etcd.io/bbolt.(*DB).freepages.func2()
lightning_lnd_1 | go.etcd.io/bbolt@v1.4.3/db.go:1248 +0x84
lightning_lnd_1 | created by go.etcd.io/bbolt.(*DB).freepages in goroutine 1
lightning_lnd_1 | go.etcd.io/bbolt@v1.4.3/db.go:1246 +0x164
lightning_lnd_1 | 2026-10-12 15:10:36.462 [WRN] LTND: Config 'bitcoin.active' is deprecated, please remove it
lightning_lnd_1 | 2026-10-12 15:10:36.462 [INF] LTND: Version Info rev=390b2d version=0.21.4-beta commit=v0.21.4-beta debuglevel=production logging=info
lightning_lnd_1 | 2026-10-12 15:10:36.462 [INF] LTND: Network Info rev=390b2d active_chain=Bitcoin network=mainnet
lightning_lnd_1 | 2026-10-12 15:10:36.463 [INF] RPCS: RPC server listening on 0.0.0.0:10009
lightning_lnd_1 | 2026-10-12 15:10:36.469 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
lightning_lnd_1 | 2026-10-12 15:10:36.469 [INF] LTND: Opening the main database, this might take a few minutes...
lightning_lnd_1 | 2026-10-12 15:10:36.469 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lightning_lnd_1 | 2026-10-12 15:10:37.409 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
lightning_lnd_1 |
Can anyone help me get the node back to life?
