That means is rescanning the UTXOs. Look into settings - lnd logs
Force closing take more time than usual. Be patient
You can contact Hampus in Blixt telegram group. Heâs very helpful if you have issues.
Blixt method ist very good. I have all my coins back now.
Notice:
Enable tor to close the tor channels!
When the recovery process is completed, rescan the Wallet/Blockchain. Settings/Debug/Rescan Wallet.
@DarthCoin
Do you think the âfailed to fetch block hash problemâ could have been solved with a rescan of the wallet UTXOs?
Like you described in the troubleshooting guide:
Step 1 - Enter using SSH into your node:
Step 2 - execute the following command to rescan walletâs UTXOs:
sed -i âs/[Application Options]/[Application Options]\nreset-wallet-transactions=true/g;â ~/umbrel/lnd/lnd.conf && sudo reboot
Step 3 - Wait some time so LND can rescan all walletâs UTXOs. If it solve the issue, run this to stop it from rescanning on a future restart:
sed -i âs/reset-wallet-transactions=true//g;â ~/umbrel/lnd/lnd.conf && sudo reboot
Wait, it can take quite a while.
Maybe, but if is a physical corruption of the drive blocks (not btc blocks) is better a re-format, a rescan doesnât do shit.
The rescan of the wallet played out. lnd is working now.
The error message âpanic: unable to synchronize walletâ is gone und umbrel is doing his job.
I could have saved my channels.
@solution21
Maybe you can fix your umbrel without SCB.
