Is anyone interested into having a Kiosk desktop of the Umbrel GUI on the terminal side?
Let me know if anyone is interested and I’ll post a guide on what you need to do.
Just post it. ![]()
Thanks in advance!
ok. To put a kiosk on the terminal:
sudo -i
apt update
apt upgrade
apt install -y xorg openbox chromium lightdm
Then select keyboard layout when prompted
useradd -m kiosk
sed -i '/#autologin-user=/c\autologin-user=kiosk' /etc/lightdm/lightdm.conf
sed -i '/#user-session=/c\user-session=openbox' /etc/lightdm/lightdm.conf
su - kiosk
mkdir -p /home/kiosk/.config/openbox
printf "chromium --kiosk http://umbrel.local" > /home/kiosk/.config/openbox/autostart
exit
reboot
Then it will show up. There might be a “page is not displayed” for a second or two until the web GUI comes online,
Enjoy
