Jam not showing my bond value on the orderbook
Im a bit of a noob. I have a unmbrel home on ver1.3
The BTC full node is on ver 28.0.0 and has the following settings on.
  • Outgoing Connections to Clearnet Peers
  • Outgoing Connections to Tor Peers
  • Make All Outgoing Connections to Clearnet Peers Over Tor
The assumption is that jam will now only work over Tor
I have a UTXO in jarA and a UTXO in jarB.
jarA seems to have been successfully locked as a bond
and jarB seems to have successfully offered to the market
The problem is when I look at the orderbook I see my my market offer in jarB but it does not show my bond value.
I dont full understand the jam app logs but it has a lot of
  • “lost IRC connection to darkircxxxxxxxxx.onion” messages
  • “builtins.IndexError: tuple index out of range”
  • "failed to connect to peer xxxxxxxx.onion.5222
Is this all happening because I am using Tor and should I turn Tor off on the BTC full node. Im too scared to restart jam or the umbrel in case it all gets lost (silly! I know).
Hi, did you find the answer somewhere? I have the exact same issue…
