Installing 2 hard drives on Umbrel
Hi Folks,
I’m assembling my first full node and have a question about configuration.
Basically, when I install Umbrel, I’d like the OS on the 256gb primary drive, and use the 1TB drive to house the Blockchain.
Can this be done natively within the Umbrel set up or do I have to deal with the command line (eeks)…
Many thanks!
This cannot be done natively yet in the current 1.3 release. Supposedly, it will be possible in the upcoming v1.4 which is still in beta.
However, it can be achieved through some configuration. You can guide yourself with this: HOW-TO Using 2 SDDs in umbrellos (in a simple and practical way)
Many Thanks for the reply!
