Hi, whenever I try to change my Immich settings I can’t do that, for example this happens when I try to change the folder template to save the images:
I couldn’t find any solution, it seems that there’re several issues with Immich
Still no solution for this ![]()
It seems it has been solved!!!
Thanks a lot
