I installed umbrel 1.3.0 few days ago on my RPi 5 with 8GB and a 2TB SSD NVme, No SD
Blockchain in fully synced and now electrs tries to sync too.
But since day one I have several freezes over the day. The web UI is not reachable nor SSH, but I can ping the pi.
When I repower the pi I checked the journal and saw this.
Dec 20 00:14:13 umbrel mender[344]: time="2024-12-19T23:14:13Z" level=error msg="Failed to authorize with \"\": failed to build authorization request: failed to obtain authorization message data: failed to obtain identity data: failed to call /usr/share/mender/identity/mender-device-identity: fork/exec /usr/share/mender/identity/mender-device-identity: no such file or directory"
Dec 20 00:14:13 umbrel mender[344]: time="2024-12-19T23:14:13Z" level=warning msg="Reauthorization failed with error: transient error: authorization request failed"
Dec 20 00:14:13 umbrel mender[344]: time="2024-12-19T23:14:13Z" level=error msg="Failed to submit inventory data: transient error: authorization request failed"
Dec 20 00:14:13 umbrel mender[344]: time="2024-12-19T23:14:13Z" level=error msg="inventory submit failed: transient error: authorization request failed"
Dec 20 00:14:13 umbrel mender[344]: time="2024-12-19T23:14:13Z" level=warning msg="Failed to refresh inventory: failed to submit inventory data: inventory submit failed: transient error: authorization request failed"
So I tried this command
sudo mender install https://download.umbrel.com/release/1.3.0/umbrelos-pi.update && sudo rugpi-ctrl system reboot --spare
as recommended here and saw this:
INFO[0000] 'UpdateControlMapExpirationTimeSeconds' is not set in the Mender configuration file. Falling back to the default of 2*UpdatePollIntervalSeconds
INFO[0000] 'UpdateControlMapBootExpirationTimeSeconds' is not set in the Mender configuration file. Falling back to the default of 600 seconds
INFO[0000] No configuration files present. Using defaults
WARN[0000] No server URL(s) specified in mender configuration.
WARN[0000] Server entry 1 has no associated server URL.
INFO[0000] No dual rootfs configuration present
INFO[0000] Performing remote update from: [https://download.umbrel.com/release/1.3.0/umbrelos-pi.update].
Installing Artifact of size 1122937856...
INFO[0001] No public key was provided for authenticating the artifact
INFO[0001] Output (stdout) from command "/usr/share/mender/modules/v3/rugpi-image": Hot partition is already the default!
INFO[0002] Output (stdout) from command "/usr/share/mender/modules/v3/rugpi-image": Copying partitions...
INFO[0002] Output (stdout) from command "/usr/share/mender/modules/v3/rugpi-image": Found 0,CONFIG kind: 0x0c, start: 8192, size: 524288
INFO[0003] Output (stdout) from command "/usr/share/mender/modules/v3/rugpi-image": Found 1,BOOT-A kind: 0x0c, start: 532480, size: 262144
And here some investigations:
fdisk
umbrel@umbrel:~$ sudo fdisk -l
Disk /dev/ram0: 4 MiB, 4194304 bytes, 8192 sectors
Units: sectors of 1 * 512 = 512 bytes
Sector size (logical/physical): 512 bytes / 16384 bytes
I/O size (minimum/optimal): 16384 bytes / 16384 bytes
Disk /dev/ram1: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram2: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram3: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram4: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram5: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram6: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram7: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram8: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram9: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram10: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram11: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram12: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram13: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram14: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/ram15: 4 MiB, 4194304 bytes, 8192 sectors
Disk /dev/nvme0n1: 1.82 TiB, 2000398934016 bytes, 3907029168 sectors
Disk model: CT2000P3PSSD8
Sector size (logical/physical): 512 bytes / 512 bytes
I/O size (minimum/optimal): 512 bytes / 512 bytes
Disklabel type: dos
Disk identifier: 0xaa887561
Device Boot Start End Sectors Size Id Type
/dev/nvme0n1p1 8192 532479 524288 256M c W95 FAT32 (LBA)
/dev/nvme0n1p2 532480 794623 262144 128M c W95 FAT32 (LBA)
/dev/nvme0n1p3 794624 1056767 262144 128M c W95 FAT32 (LBA)
/dev/nvme0n1p4 1056768 3907029167 3905972400 1.8T 5 Extended
/dev/nvme0n1p5 1064960 11550719 10485760 5G 83 Linux
/dev/nvme0n1p6 11558912 22044671 10485760 5G 83 Linux
/dev/nvme0n1p7 22052864 3907029167 3884976304 1.8T 83 Linux
df- h
overlay 1.8T 768G 963G 45% /
tmp 4.0G 9.0M 4.0G 1% /run
/dev/nvme0n1p7 1.8T 768G 963G 45% /run/rugpi/mounts/data
/dev/nvme0n1p5 3.3G 2.9G 230M 93% /run/rugpi/mounts/system
/dev/nvme0n1p1 256M 12K 256M 1% /run/rugpi/mounts/config
/dev/nvme0n1p2 128M 89M 40M 70% /boot
devtmpfs 4.0M 0 4.0M 0% /dev
tmpfs 4.0G 0 4.0G 0% /dev/shm
tmpfs 5.0M 0 5.0M 0% /run/lock
tmpfs 806M 0 806M 0% /run/user/1000
sudo du -h /run/rugpi/mounts/system | sort -rh | head -20
2.9G /run/rugpi/mounts/system
2.1G /run/rugpi/mounts/system/usr
845M /run/rugpi/mounts/system/usr/lib
659M /run/rugpi/mounts/system/images
536M /run/rugpi/mounts/system/usr/share
498M /run/rugpi/mounts/system/usr/lib/aarch64-linux-gnu
395M /run/rugpi/mounts/system/usr/bin
147M /run/rugpi/mounts/system/usr/share/nodejs
140M /run/rugpi/mounts/system/usr/libexec
137M /run/rugpi/mounts/system/usr/libexec/docker
136M /run/rugpi/mounts/system/usr/share/locale
136M /run/rugpi/mounts/system/usr/libexec/docker/cli-plugins
102M /run/rugpi/mounts/system/usr/lib/gcc/aarch64-linux-gnu/12
94M /run/rugpi/mounts/system/usr/local/lib/node_modules/umbreld
86M /run/rugpi/mounts/system/usr/share/doc
