Loading continues on the screen to get the 24 character secret word. What’s wrong? Can I wait a while?
Sorry to hear you’re having issues - are you running on 4.10? If so, there was a bug that some users were running into with the seed phrase pages, the fix, for now, is to reflash your SD card with Umbrel 4.9 (make sure to format your hard drive/SSD as well, it won’t work otherwise)
