How to restart lnd after a config change
Hi folks,
What’s the preferred way of restarting lnd to apply a config change?
Does it have to be a full node restart or can we just restart the docker container?
What would be the command for that?
Thank you,
Heebs
See https://plebnet.wiki/wiki/LND_Configuration_Settings
For the Settings To Take Effect
For the settings to take effect, you will need to restart lnd. Do not restart entire node.
Restart lnd cd ~/umbrel ; docker-compose restart lnd; docker-compose ps
For non umbrel, the instructions could be different.
This would be: sudo systemctl restart lnd
I tried using that code but I get an error message.
It is: cd ~/umbrel ; docker-compose restart lnd; docker-compose ps
Has it changed?
umbrel 0.5.1
lnd restart
/home/umbrel/umbrel/scripts/app compose lightning restart lnd
If you like to donate some sats to me:
my lightning adress
Here is a second way to restart:
  1. sudo /home/umbrel/umbrel/scripts/stop
  2. sudo /home/umbrel/umbrel/scripts/start
my lightning wallet
Restart an Umbrel app containers:
~/umbrel/scripts/app restart app-name
Restart one Umbrel app service container only:
~/umbrel/scripts/app compose app-name restart service-name
List Umbrel installed apps:
~/umbrel/scripts/app ls-installed
I signed up to the forum just to like this comment.
Very Helpfull.
Thanks very much, this option worked perfectly for the container lnd running on Umbrel version 0.5.4
Sincerely,
