How to include an external usb drive on umbrel home
Since version 1.4.2 there is a feature to add usb harddisks, to expand the storage. It is also mentioned, that this is for the umbrel home device possible. But when I plug an usb-ssd on one of these usb devices, I can’t see anything. I didn’t found any hints or docs for that. Is it not possible now? Or can you tell me, where I can find additional infos?
I would think you should be able to even though they have a notice on the AMDx64 install saying that feature is available only on the Umbrel home.
even though its very possible to do with the AMDx64 install on the OS side by adding the proper udev programming.
I just haven’t had the need for it and no one has asked for it on that platform. Even though its all the same Debian OS running docker
I have an umbrel home, but I can’t see the device!
oh that is strange. maybe rebooting it. Then go into the files, and stick a usb drive in.
