Hi all,
after a reboot I am getting these error messages:
mempool
web_1 | 2022/05/08 03:49:21 [emerg] 7#7: host not found in upstream "mempool.space" in /etc/nginx/conf.d/nginx-mempool.conf:49
web_1 | nginx: [emerg] host not found in upstream "mempool.space" in /etc/nginx/conf.d/nginx-mempool.conf:49
web_1 | 2022/05/08 03:50:27 [emerg] 8#8: host not found in upstream "mempool.space" in /etc/nginx/conf.d/nginx-mempool.conf:49
also
lightning-terminal
web_1 | 2022-05-08 03:56:06.993 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:56039->127.0.0.11:53: i/o timeout". Reconnecting...
I am also unable to start the mempool app.
Any suggestions? Thanks!
Update: I followed these steps from the troubleshooting guide:
Edit by moderators
The new, official troubleshooting guide can be found here:
Huge thanks to DarthCoin for writing and maintaining the previous community version of the guide.
One Umbrel App do not start or it can’t be installed
If you have error that a specific Umbrel App do not start or it keeps staying in “installing”, maybe the docker container for that app it wasn’t installed correctly or it hangs.
Step 1 - Enter using SSH into your Umbrel node:
Step 2 - stop Umbrel node with:
cd umbrel
Normal Linux OS use sudo ./scripts/stop
UmbrelOS (RPi) use sudo systemctl stop umbrel-startup
Step 3 - clean / reconfigure the broken container:
sudo rm .env && sudo ./scripts/configure
Step 4 - apply latest Umbrel update (replace the version number with the latest):
sudo ./scripts/update/update --repo getumbrel/umbrel#v0.4.17
Restart your node:
Normal Linux OS use sudo ./scripts/start
UmbrelOS (RPi) use sudo systemctl start umbrel-startup
You can open Umbrel dashboard, but wait until latest blocks are catching up and also electrs is synced. All txs and channels will appear after a while.
I hope the above was the correct way to face my mempool error?
Channels and txs are not showing right now, it has been taking more than an hour now. Will update if anything changes.
Check the bitcoin and lnd logs.
Is the first thing you should check if a node is not starting after a long time.
1h is not too much anyway.
SSH
cd umbrel
docker-compose logs bitcoin (see if is synced 100%)
docker-compose logs lnd (see if the wallet is unlocked and ready to catch up )
you can optional run the debug log from dashboard or command line sudo ./scripts/debug and see where is the error bottleneck.
ONLY after that start doing anything else, when you know what happen.
NEVER start fucking up the node just because you are impatient.
Thanks for your quick reply!!
So I’ll be patient for now and will check if it u fixes in 1-2 hours and get back here. Thank you alot, my dark lord
Check the logs, watch what is doing
bitcoin | 2022-05-08T08:35:43Z New outbound peer connected: version: 70016, blocks=735435, peer=67 (block-relay-only)
bitcoin | 2022-05-08T08:36:34Z Socks5() connect to 128.92.120.147:8333 failed: connection refused
bitcoin | 2022-05-08T08:36:40Z ThreadRPCServer incorrect password attempt from 10.21.21.9:46040
bitcoin | 2022-05-08T08:37:43Z ThreadRPCServer incorrect password attempt from 10.21.21.9:52814
bitcoin | 2022-05-08T08:38:47Z ThreadRPCServer incorrect password attempt from 10.21.21.9:58354
bitcoin | 2022-05-08T08:39:50Z ThreadRPCServer incorrect password attempt from 10.21.21.9:36936
bitcoin | 2022-05-08T08:40:54Z ThreadRPCServer incorrect password attempt from 10.21.21.9:43568
bitcoin | 2022-05-08T08:41:58Z ThreadRPCServer incorrect password attempt from 10.21.21.9:50420
bitcoin | 2022-05-08T08:42:55Z UpdateTip: new best=00000000000000000004e4492add073c8b9775cd99d4b736cc636ac1e9c19cf3 height=735436 version=0x2fffe004 log2_work=93.506294 tx=731842246 date=‘2022-05-08T08:42:44Z’ progress=1.000000 cache=25.4MiB(190832txo)
bitcoin | 2022-05-08T08:43:01Z ThreadRPCServer incorrect password attempt from 10.21.21.9:56554
bitcoin | 2022-05-08T08:43:15Z Socks5() connect to 37.1.222.243:8333 failed: general failure
bitcoin | 2022-05-08T08:44:05Z ThreadRPCServer incorrect password attempt from 10.21.21.9:33878
bitcoin | 2022-05-08T08:45:09Z ThreadRPCServer incorrect password attempt from 10.21.21.9:40990
bitcoin | 2022-05-08T08:46:12Z ThreadRPCServer incorrect password attempt from 10.21.21.9:47434
bitcoin | 2022-05-08T08:47:16Z ThreadRPCServer incorrect password attempt from 10.21.21.9:54296
bitcoin | 2022-05-08T08:48:19Z ThreadRPCServer incorrect password attempt from 10.21.21.9:60568
bitcoin | 2022-05-08T08:49:22Z ThreadRPCServer incorrect password attempt from 10.21.21.9:38776
bitcoin | 2022-05-08T08:50:27Z ThreadRPCServer incorrect password attempt from 10.21.21.9:45190
lnd | 2022-05-08 08:51:31.135 [ERR] LTND: Shutting down because error in main method: error creating wallet config: unable to create partial chain control: status code: 401, response: “”
lnd | 2022-05-08 08:51:31.548 [INF] LTND: Shutdown complete
lnd |
lnd | error creating wallet config: unable to create partial chain control: status code: 401, response: “”
lnd | 2022-05-08 08:51:34.006 [INF] LTND: Version: 0.14.2-beta commit=v0.14.2-beta, build=production, logging=default, debuglevel=info
lnd | 2022-05-08 08:51:34.007 [INF] LTND: Active chain: Bitcoin (network=mainnet)
lnd | 2022-05-08 08:51:34.011 [INF] RPCS: RPC server listening on 0.0.0.0:10009
lnd | 2022-05-08 08:51:34.030 [INF] RPCS: gRPC proxy started at 0.0.0.0:8080
lnd | 2022-05-08 08:51:34.030 [INF] LTND: Opening the main database, this might take a few minutes…
lnd | 2022-05-08 08:51:34.030 [INF] LTND: Opening bbolt database, sync_freelist=false, auto_compact=false
lnd | 2022-05-08 08:51:37.342 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
lnd | 2022-05-08 08:51:37.348 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
lnd | 2022-05-08 08:51:38.766 [INF] LTND: Creating local graph and channel state DB instances
lnd | 2022-05-08 08:51:41.010 [ERR] RPCS: [/lnrpc.Lightning/ListChannels]: waiting to start, RPC services not available
lnd | 2022-05-08 08:51:42.172 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: waiting to start, RPC services not available
lnd | 2022-05-08 08:51:42.215 [INF] CHDB: Checking for schema update: latest_version=24, db_version=24
lnd | 2022-05-08 08:51:42.215 [INF] LTND: Database(s) now open (time_to_open=8.185236044s)!
lnd | 2022-05-08 08:51:42.216 [INF] LTND: We’re not running within systemd
lnd | 2022-05-08 08:51:42.216 [INF] LTND: Waiting for wallet encryption password. Use lncli create to create a wallet, lncli unlock to unlock an existing wallet, or lncli changepassword to change the password of an existing wallet and unlock it.
lnd | 2022-05-08 08:51:53.043 [ERR] RPCS: [/routerrpc.Router/SubscribeHtlcEvents]: wallet locked, unlock it to enable full RPC access
lnd | 2022-05-08 08:51:57.182 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
lnd | 2022-05-08 08:52:00.106 [ERR] RPCS: [/lnrpc.Lightning/ListChannels]: wallet locked, unlock it to enable full RPC access
lnd | 2022-05-08 08:52:12.191 [ERR] RPCS: [/lnrpc.Lightning/GetInfo]: wallet locked, unlock it to enable full RPC access
lnd | 2022-05-08 08:52:18.424 [ERR] RPCS: [/lnrpc.Lightning/ListChannels]: wallet locked, unlock it to enable full RPC access
This:
Part 1)
Login to your node with an SSH client / Power terminal via
ssh -t umbrel@umbrel.local
The prompted password is your dashboard password.
Then execute:
cd ~/umbrel && docker-compose exec lnd /bin/bash
Then:
lncli unlock
When prompted, enter the password you have used logging into your Umbrel user interface.
Done. Now open Umbrel dashboard page and login. Verify like above if that was successful.
Gives me the following output:
[lncli] rpc error: code = Unavailable desc = error reading from server: EOF
The second part worked! It’s back online!
Part 2)
In case the above doesn’t work and your wallet is still locked, add the following steps
Make a backup of your current lnd.conf
cp ~/umbrel/lnd/lnd.conf ~/umbrel/lnd/lnd.bak
Delete your current lnd.conf, re-configure Umbrel and restart the node
rm ~/umbrel/lnd/lnd.conf && ~/umbrel/scripts/configure && sudo reboot
However, I am still seeing errors in the logs:
> mempool
> mariadb_1 | 2022-05-08 9:41:45 0 [Note] mysqld: ready for connections.
> api_1 | May 8 09:46:17 [97] WARN: runMainLoop error: Block height out of range. Retrying in 60 sec.
> mariadb_1 | Version: '10.5.12-MariaDB-1:10.5.12+maria~focal' socket: '/run/mysqld/mysqld.sock' port: 3306 mariadb.org binary distribution
> api_1 | May 8 09:46:17 [97] DEBUG: {"code":-8}
> mariadb_1 | 2022-05-08 9:41:45 3 [Warning] Aborted connection 3 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.27' (This connection closed normally without authentication)
> api_1 | May 8 09:47:17 [97] DEBUG: New block found (#735444)!
> mariadb_1 | 2022-05-08 9:41:45 0 [Note] InnoDB: Buffer pool(s) load completed at 220508 9:41:45
> api_1 | May 8 09:47:17 [97] WARN: runMainLoop error: Block height out of range. Retrying in 60 sec.
> mariadb_1 | 2022-05-08 9:41:45 4 [Warning] Aborted connection 4 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> api_1 | May 8 09:47:17 [97] DEBUG: {"code":-8}
> mariadb_1 | 2022-05-08 9:41:56 5 [Warning] Aborted connection 5 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> api_1 | May 8 09:48:18 [97] DEBUG: New block found (#735444)!
> mariadb_1 | 2022-05-08 9:42:04 7 [Warning] Aborted connection 7 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> api_1 | May 8 09:48:18 [97] WARN: runMainLoop error: Block height out of range. Retrying in 60 sec.
> mariadb_1 | 2022-05-08 9:42:13 8 [Warning] Aborted connection 8 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> api_1 | May 8 09:48:18 [97] DEBUG: {"code":-8}
> mariadb_1 | 2022-05-08 9:42:21 9 [Warning] Aborted connection 9 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> api_1 | May 8 09:49:18 [97] DEBUG: New block found (#735444)!
> mariadb_1 | 2022-05-08 9:42:30 10 [Warning] Aborted connection 10 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> api_1 | May 8 09:49:18 [97] DEBUG: {"code":-8}
> mariadb_1 | 2022-05-08 9:42:39 11 [Warning] Aborted connection 11 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> api_1 | May 8 09:49:18 [97] WARN: runMainLoop error: Block height out of range. Retrying in 60 sec.
> mariadb_1 | 2022-05-08 9:42:52 12 [Warning] Aborted connection 12 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> mariadb_1 | 2022-05-08 9:43:12 13 [Warning] Aborted connection 13 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> mariadb_1 | 2022-05-08 9:43:44 14 [Warning] Aborted connection 14 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> mariadb_1 | 2022-05-08 9:44:42 15 [Warning] Aborted connection 15 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> mariadb_1 | 2022-05-08 9:45:49 16 [Warning] Aborted connection 16 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> mariadb_1 | 2022-05-08 9:46:55 17 [Warning] Aborted connection 17 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> mariadb_1 | 2022-05-08 9:48:01 18 [Warning] Aborted connection 18 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> mariadb_1 | 2022-05-08 9:49:07 19 [Warning] Aborted connection 19 to db: 'unconnected' user: 'unauthenticated' host: '10.21.21.26' (This connection closed normally without authentication)
> lightning-terminal
> web_1 | 2022-05-08 09:44:57.917 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:40637->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:44:57.918 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:40637->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:44:57.925 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:46762->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:45:05.913 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {swap.lightning.today:11010 swap.lightning.today:11010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:46617->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:45:30.239 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:60177->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:45:33.869 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:56317->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:45:38.479 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {swap.lightning.today:11010 swap.lightning.today:11010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:36177->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:46:18.736 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:60289->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:46:21.795 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:46446->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:46:27.491 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {swap.lightning.today:11010 swap.lightning.today:11010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:53295->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:46:31.252 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:35565->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:46:33.425 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:52059->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:46:35.658 [INF] LITD: Handling static file request: /
> web_1 | 2022-05-08 09:47:38.590 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:49571->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:47:39.859 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:47262->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:47:44.322 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {swap.lightning.today:11010 swap.lightning.today:11010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:35738->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:47:50.493 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:43358->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:49:31.191 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:51044->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:49:50.744 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {swap.lightning.today:11010 swap.lightning.today:11010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:44426->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:49:53.978 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:36309->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:49:53.979 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:36309->127.0.0.11:53: i/o timeout". Reconnecting...
> web_1 | 2022-05-08 09:50:00.821 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:57604->127.0.0.11:53: i/o timeout". Reconnecting...
what have to do mempool with your working node?
Delete mempool app, is broken.
Install it again IF YOU REALLY NEED IT.
I am still trying to understand why RPi users still insist in installing mempool app. Is taking a lot of resources just for consulting a damn tx once in a while.
Its not that I need mempool in particular. I wasn’t aware that it consumes so many resources, I can gladly uninstall it.
However I’m having issues with other apps as well. For instance with lightning terminal:
lightning-terminal
web_1 | 2022-05-08 13:53:43.144 [INF] LITD: Handling gRPC web request: /poolrpc.Trader/ListAccounts
web_1 | 2022-05-08 13:53:43.146 [INF] LITD: Handling gRPC web request: /poolrpc.Trader/NextBatchInfo
web_1 | 2022-05-08 13:53:43.146 [INF] LITD: Handling gRPC web request: /poolrpc.Trader/ListOrders
web_1 | 2022-05-08 13:53:43.146 [INF] LITD: Handling gRPC web request: /poolrpc.Trader/LeaseDurations
web_1 | 2022-05-08 13:53:45.611 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:54530->127.0.0.11:53: i/o timeout". Reconnecting...
web_1 | 2022-05-08 13:53:51.418 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:58444->127.0.0.11:53: i/o timeout". Reconnecting...
web_1 | 2022-05-08 13:53:51.418 [ERR] AUCT: [/poolrpc.ChannelAuctioneer/Terms]: rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:58444->127.0.0.11:53: i/o timeout"
web_1 | 2022-05-08 13:53:51.419 [WRN] POOL: unable to query auctioneer terms: rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:58444->127.0.0.11:53: i/o timeout"
web_1 | 2022-05-08 13:53:51.449 [INF] LITD: Handling gRPC web request: /poolrpc.Trader/BatchSnapshots
web_1 | 2022-05-08 13:53:51.451 [ERR] AUCT: [/poolrpc.ChannelAuctioneer/BatchSnapshots]: rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:58444->127.0.0.11:53: i/o timeout"
web_1 | 2022-05-08 13:53:51.457 [INF] LITD: Handling gRPC web request: /poolrpc.Trader/Leases
web_1 | 2022-05-08 13:53:51.499 [ERR] AUCT: [/poolrpc.ChannelAuctioneer/NodeRating]: rpc error: code = Unavailable desc = connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:58444->127.0.0.11:53: i/o timeout"
web_1 | 2022-05-08 13:53:51.845 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {swap.lightning.today:11010 swap.lightning.today:11010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:57925->127.0.0.11:53: i/o timeout". Reconnecting...
web_1 | 2022-05-08 13:53:57.071 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:49441->127.0.0.11:53: i/o timeout". Reconnecting...
web_1 | 2022-05-08 13:54:05.477 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {swap.lightning.today:11010 swap.lightning.today:11010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:56448->127.0.0.11:53: i/o timeout". Reconnecting...
web_1 | 2022-05-08 13:54:05.806 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:48444->127.0.0.11:53: i/o timeout". Reconnecting...
web_1 | 2022-05-08 13:54:05.807 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:48444->127.0.0.11:53: i/o timeout". Reconnecting...
web_1 | 2022-05-08 13:54:09.212 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:37392->127.0.0.11:53: i/o timeout". Reconnecting...
web_1 | 2022-05-08 13:54:22.386 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {swap.lightning.today:11010 swap.lightning.today:11010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup swap.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:55516->127.0.0.11:53: i/o timeout". Reconnecting...
web_1 | 2022-05-08 13:54:22.794 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:57939->127.0.0.11:53: i/o timeout". Reconnecting...
web_1 | 2022-05-08 13:54:22.795 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {pool.lightning.finance:12010 pool.lightning.finance:12010 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup pool.lightning.finance on 127.0.0.11:53: read udp 127.0.0.1:57939->127.0.0.11:53: i/o timeout". Reconnecting...
web_1 | 2022-05-08 13:54:23.736 [WRN] GRPC: [core] grpc: addrConn.createTransport failed to connect to {mailbox.terminal.lightning.today:443 mailbox.terminal.lightning.today:443 <nil> 0 <nil>}. Err: connection error: desc = "transport: Error while dialing dial tcp: lookup mailbox.terminal.lightning.today on 127.0.0.11:53: read udp 127.0.0.1:44552->127.0.0.11:53: i/o timeout". Reconnecting...
Unfortunately, reinstall doesn’t fit it
I’m getting http errors in lightning shell as well. It seems to be a deeper issue
Looks more connection problems than internal.
Are you also using Pi-hole app?
Yes, I am. You think pi hole blocks those connections?
I might need to add that I’ve just recently installed pi hole and wasn’t facing any problems before. However, I really like the idea of ad blocking for my network.
Ok but then configure it well.
If you do not know what are you doing, then better don’t do it.
Any hints for a working configuration?
uninstall
magically all will work just fine.
So I guess I still need adblock widgets
No, I don’t use any pihole or widgets.
I just use a good DNS provider that blocks the shit.
Also a chromium browser that blocks everything.
Pi-hole is good, but be careful how you configure it and use it.
Would you share which dns you use?
I never did research on that and typically just set it to 8.8.8.8/8.8.4.4 …
Did you tried 9.9.9.9 ?
Ar many more of them. Just change into your PC or even router the DNS
https://duckduckgo.com/?q=ad+block+dns&hps=1&ia=web
Pi-hole is for more advanced stuff, but for just get rid of annoying ads, use a damn good DNS.
Anyways, thanks for your help!
