Host Key changed... can't SSH into my node
I recently recovered my Umbrel onto a new SSD, and it is currently syncing the blockchain. I attempted to SSH into it so that I can import my lightning backups once the full sync is complete. I ran into an error message below. I am a command line noob and don’t know how to fix the error.
I’m having a similar issue
try this https://www.youtube.com/watch?v=SOjtB4n8WiE
Thanks I ended up finidng this and it worked:
"If you don’t use SSH for anything else you can just delete the file:
rm ~/.ssh/known_hosts
Now try and SSH in to your Umbrel again and you won’t see the error."
