Having problems installing a second umbrel on the same network
I have an umbrel installed under umbrel.local, also using tailscale so I know the IP of the node.
I have installed a second umbrel, reading thru the community pages I understood the second one would be reachable under umbrel2-local but that is not the case, the second one is under umbrel.local and I cannot reach my first one even thru the IP.
Any advise?
Thanks
Connect with ethernetcable
I was able to solve the problem.
  1. ssh to the first umbrel.
  2. update the host name to the new name with the command hostnamectl set-hostname hostname
  3. reboot
  4. ssh to the second umbrel
  5. update the host name to the new name with the command hostnamectl set-hostname hostname
