My mistake, totally forgot it was updating. Best to reset maybe but how?
I can connect from powershell but not from browser. Have tried some things but little noob with this.
Booting Linux on physical CPU 0x0000000000 [0x410fd083]
[ 0.000000] Linux version 5.10.63-v8+ (dom@buildbot) (aarch64-linux-gnu-gcc-8 (Ubuntu/Linaro 8.4.0-3ubuntu1) 8.4.0, GNU ld (GNU Binutils for Ubuntu) 2.34) #1457 SMP PREEMPT Tue Sep 28 11:27:02 BST 2021
[ 0.000000] random: fast init done
[ 0.000000] Machine model: Raspberry Pi 4 Model B Rev 1.4
[ 0.000000] efi: UEFI not found.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000001ac00000, size 320 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000000000000-0x000000003fffffff]
[ 0.000000] DMA32 [mem 0x0000000040000000-0x00000000ffffffff]
[ 0.000000] Normal [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000000000000-0x000000003b3fffff]
[ 0.000000] node 0: [mem 0x0000000040000000-0x00000000fbffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x00000001ffffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000000000000-0x00000001ffffffff]
[ 0.000000] On node 0 totalpages: 2061312
[ 0.000000] DMA zone: 3792 pages used for memmap
[ 0.000000] DMA zone: 0 pages reserved
[ 0.000000] DMA zone: 242688 pages, LIFO batch:63
[ 0.000000] DMA32 zone: 12288 pages used for memmap
[ 0.000000] DMA32 zone: 770048 pages, LIFO batch:63
[ 0.000000] Normal zone: 16384 pages used for memmap
[ 0.000000] Normal zone: 1048576 pages, LIFO batch:63
[ 0.000000] percpu: Embedded 32 pages/cpu s91416 r8192 d31464 u131072
[ 0.000000] pcpu-alloc: s91416 r8192 d31464 u131072 alloc=32*4096
[ 0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Spectre-v2
[ 0.000000] CPU features: detected: Spectre-v4
[ 0.000000] CPU features: detected: ARM errata 1165522, 1319367, or 1530923
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2028848
[ 0.000000] Kernel command line: coherent_pool=1M 8250.nr_uarts=0 snd_bcm2835.enable_compat_alsa=0 snd_bcm2835.enable_hdmi=1 smsc95xx.macaddr=E4:5F:01:6F:3B:A3 vc_mem.mem_base=0x3ec00000 vc_mem.mem_size=0x40000000 usb-storage.quirks=152d:1561:u,152d:1576:u,152d:0578:u,125f:a76a:u,04e8:61b6:u console=ttyS0,115200 console=tty1 root=PARTUUID=f3713887-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
[ 0.000000] Kernel parameter elevator= does not have any effect anymore.
Please use sysfs to set IO scheduler for individual devices.
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x0000000037400000-0x000000003b400000] (64MB)
[ 0.000000] Memory: 7669128K/8245248K available (11136K kernel code, 1946K rwdata, 3984K rodata, 3712K init, 1260K bss, 248440K reserved, 327680K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
[ 0.000000] ftrace: allocating 36758 entries in 144 pages
[ 0.000000] ftrace: allocated 144 pages with 2 groups
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=4.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=4
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GIC: Using split EOI/Deactivate mode
[ 0.000000] random: get_random_bytes called from start_kernel+0x3b0/0x570 with crng_init=1
[ 0.000000] arch_timer: cp15 timer(s) running at 54.00MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xc743ce346, max_idle_ns: 440795203123 ns
[ 0.000006] sched_clock: 56 bits at 54MHz, resolution 18ns, wraps every 4398046511102ns
[ 0.000261] Console: colour dummy device 80x25
[ 0.000824] printk: console [tty1] enabled
[ 0.000885] Calibrating delay loop (skipped), value calculated using timer frequency… 108.00 BogoMIPS (lpj=216000)
[ 0.000927] pid_max: default: 32768 minimum: 301
[ 0.001080] LSM: Security Framework initializing
[ 0.001369] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001494] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.002779] cgroup: Disabling memory control group subsystem
[ 0.005169] rcu: Hierarchical SRCU implementation.
[ 0.006246] EFI services will not be available.
[ 0.006771] smp: Bringing up secondary CPUs …
[ 0.007757] Detected PIPT I-cache on CPU1
[ 0.007836] CPU1: Booted secondary processor 0x0000000001 [0x410fd083]
[ 0.008971] Detected PIPT I-cache on CPU2
[ 0.009019] CPU2: Booted secondary processor 0x0000000002 [0x410fd083]
[ 0.010103] Detected PIPT I-cache on CPU3
[ 0.010151] CPU3: Booted secondary processor 0x0000000003 [0x410fd083]
[ 0.010301] smp: Brought up 1 node, 4 CPUs
[ 0.010388] SMP: Total of 4 processors activated.
[ 0.010411] CPU features: detected: 32-bit EL0 Support
[ 0.010434] CPU features: detected: CRC32 instructions
[ 0.010456] CPU features: detected: 32-bit EL1 Support
[ 0.043355] CPU: All CPU(s) started at EL2
[ 0.043437] alternatives: patching kernel code
[ 0.045446] devtmpfs: initialized
[ 0.055955] Enabled cp15_barrier support
[ 0.056019] Enabled setend support
[ 0.056274] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.056320] futex hash table entries: 1024 (order: 4, 65536 bytes, linear)
[ 0.064819] pinctrl core: initialized pinctrl subsystem
[ 0.065616] DMI not present or invalid.
[ 0.066007] NET: Registered protocol family 16
[ 0.069107] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.069389] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.070317] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.070427] audit: initializing netlink subsys (disabled)
[ 0.070829] audit: type=2000 audit(0.068:1): state=initialized audit_enabled=0 res=1
[ 0.071321] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.071777] cpuidle: using governor menu
[ 0.072176] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.072359] ASID allocator initialised with 65536 entries
[ 0.072505] Serial: AMBA PL011 UART driver
[ 0.102396] bcm2835-mbox fe00b880.mailbox: mailbox enabled
[ 0.108347] raspberrypi-firmware soc:firmware: Attached to firmware from 2021-09-28T11:27:35, variant start
[ 0.112355] raspberrypi-firmware soc:firmware: Firmware hash is 778b6a4f3c7d8d48bb63c02c47bcfbac79417bea
[ 0.146566] bcm2835-dma fe007000.dma: DMA legacy API manager, dmachans=0x1
[ 0.150373] vgaarb: loaded
[ 0.150803] SCSI subsystem initialized
[ 0.151023] usbcore: registered new interface driver usbfs
[ 0.151091] usbcore: registered new interface driver hub
[ 0.151168] usbcore: registered new device driver usb
[ 0.151490] usb_phy_generic phy: supply vcc not found, using dummy regulator
[ 0.153357] clocksource: Switched to clocksource arch_sys_counter
[ 1.170487] VFS: Disk quotas dquot_6.6.0
[ 1.170608] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 1.170780] FS-Cache: Loaded
[ 1.171037] CacheFiles: Loaded
[ 1.181692] NET: Registered protocol family 2
[ 1.182647] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 1.188660] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 1.188783] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 1.189273] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 1.190311] TCP: Hash tables configured (established 65536 bind 65536)
[ 1.190651] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.190802] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 1.191257] NET: Registered protocol family 1
[ 1.192265] RPC: Registered named UNIX socket transport module.
[ 1.192295] RPC: Registered udp transport module.
[ 1.192315] RPC: Registered tcp transport module.
[ 1.192335] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 1.192367] PCI: CLS 0 bytes, default 64
[ 1.194726] hw perfevents: enabled with armv8_cortex_a72 PMU driver, 7 counters available
[ 1.195036] kvm [1]: IPA Size Limit: 44 bits
[ 1.196225] kvm [1]: vgic interrupt IRQ9
[ 1.196513] kvm [1]: Hyp mode initialized successfully
[ 1.198742] Initialise system trusted keyrings
[ 1.199105] workingset: timestamp_bits=46 max_order=21 bucket_order=0
[ 1.205530] zbud: loaded
[ 1.207311] FS-Cache: Netfs ‘nfs’ registered for caching
[ 1.207979] NFS: Registering the id_resolver key type
[ 1.208027] Key type id_resolver registered
[ 1.208049] Key type id_legacy registered
[ 1.208173] nfs4filelayout_init: NFSv4 File Layout Driver Registering…
[ 1.208199] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering…
[ 1.209378] Key type asymmetric registered
[ 1.209405] Asymmetric key parser ‘x509’ registered
[ 1.209464] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 249)
[ 1.209756] io scheduler mq-deadline registered
[ 1.209782] io scheduler kyber registered
[ 1.213714] brcm-pcie fd500000.pcie: host bridge /scb/pcie@7d500000 ranges:
[ 1.213759] brcm-pcie fd500000.pcie: No bus range found for /scb/pcie@7d500000, using [bus 00-ff]
[ 1.213844] brcm-pcie fd500000.pcie: MEM 0x0600000000…0x063fffffff -> 0x00c0000000
[ 1.213934] brcm-pcie fd500000.pcie: IB MEM 0x0000000000…0x01ffffffff -> 0x0400000000
[ 1.279456] brcm-pcie fd500000.pcie: link up, 5.0 GT/s PCIe x1 (SSC)
[ 1.279839] brcm-pcie fd500000.pcie: PCI host bridge to bus 0000:00
[ 1.279870] pci_bus 0000:00: root bus resource [bus 00-ff]
[ 1.279905] pci_bus 0000:00: root bus resource [mem 0x600000000-0x63fffffff] (bus address [0xc0000000-0xffffffff])
[ 1.280006] pci 0000:00:00.0: [14e4:2711] type 01 class 0x060400
[ 1.280249] pci 0000:00:00.0: PME# supported from D0 D3hot
[ 1.284351] pci 0000:01:00.0: [1106:3483] type 00 class 0x0c0330
[ 1.284486] pci 0000:01:00.0: reg 0x10: [mem 0x00000000-0x00000fff 64bit]
[ 1.284914] pci 0000:01:00.0: PME# supported from D0 D3hot
[ 1.300784] pci 0000:00:00.0: BAR 8: assigned [mem 0x600000000-0x6000fffff]
[ 1.300821] pci 0000:01:00.0: BAR 0: assigned [mem 0x600000000-0x600000fff 64bit]
[ 1.300871] pci 0000:00:00.0: PCI bridge to [bus 01]
[ 1.300902] pci 0000:00:00.0: bridge window [mem 0x600000000-0x6000fffff]
[ 1.308148] iproc-rng200 fe104000.rng: hwrng registered
[ 1.308507] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000000(1024 MiB)
[ 1.309331] gpiomem-bcm2835 fe200000.gpiomem: Initialised: Registers at 0xfe200000
[ 1.309836] cacheinfo: Unable to detect cache hierarchy for CPU 0
[ 1.321236] brd: module loaded
[ 1.333649] loop: module loaded
[ 1.335613] Loading iSCSI transport class v2.0-870.
[ 1.338790] libphy: Fixed MDIO Bus: probed
[ 1.340353] bcmgenet fd580000.ethernet: GENET 5.0 EPHY: 0x0000
[ 1.349392] libphy: bcmgenet MII bus: probed
[ 1.385641] unimac-mdio unimac-mdio.-19: Broadcom UniMAC MDIO bus
[ 1.386758] usbcore: registered new interface driver r8152
[ 1.386836] usbcore: registered new interface driver lan78xx
[ 1.386911] usbcore: registered new interface driver smsc95xx
[ 1.434055] pci 0000:00:00.0: enabling device (0000 -> 0002)
[ 1.434251] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.434296] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 1.435076] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
[ 1.436371] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 1.436404] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.436430] usb usb1: Product: xHCI Host Controller
[ 1.436452] usb usb1: Manufacturer: Linux 5.10.63-v8+ xhci-hcd
[ 1.436474] usb usb1: SerialNumber: 0000:01:00.0
[ 1.437174] hub 1-0:1.0: USB hub found
[ 1.437281] hub 1-0:1.0: 1 port detected
[ 1.437970] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 1.438006] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 1.438042] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 1.438467] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 1.438497] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 1.438523] usb usb2: Product: xHCI Host Controller
[ 1.438544] usb usb2: Manufacturer: Linux 5.10.63-v8+ xhci-hcd
[ 1.438566] usb usb2: SerialNumber: 0000:01:00.0
[ 1.439195] hub 2-0:1.0: USB hub found
[ 1.439271] hub 2-0:1.0: 4 ports detected
[ 1.440759] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
[ 1.441041] dwc_otg: FIQ enabled
[ 1.441052] dwc_otg: NAK holdoff enabled
[ 1.441062] dwc_otg: FIQ split-transaction FSM enabled
[ 1.441076] Module dwc_common_port init
[ 1.441635] usbcore: registered new interface driver uas
[ 1.441742] usbcore: registered new interface driver usb-storage
[ 1.441970] mousedev: PS/2 mouse device common for all mice
[ 1.443825] bcm2835-wdt bcm2835-wdt: Broadcom BCM2835 watchdog timer
[ 1.446913] sdhci: Secure Digital Host Controller Interface driver
[ 1.446943] sdhci: Copyright© Pierre Ossman
[ 1.447592] mmc-bcm2835 fe300000.mmcnr: could not get clk, deferring probe
[ 1.448113] sdhci-pltfm: SDHCI platform and OF driver helper
[ 1.451931] ledtrig-cpu: registered to indicate activity on CPUs
[ 1.452248] hid: raw HID events driver © Jiri Kosina
[ 1.452436] usbcore: registered new interface driver usbhid
[ 1.452459] usbhid: USB HID core driver
[ 1.452869] ashmem: initialized
[ 1.461271] Initializing XFRM netlink socket
[ 1.461369] NET: Registered protocol family 17
[ 1.461505] Key type dns_resolver registered
[ 1.462111] registered taskstats version 1
[ 1.462153] Loading compiled-in X.509 certificates
[ 1.462671] Key type ._fscrypt registered
[ 1.462696] Key type .fscrypt registered
[ 1.462716] Key type fscrypt-provisioning registered
[ 1.473759] uart-pl011 fe201000.serial: there is not valid maps for state default
[ 1.474078] uart-pl011 fe201000.serial: cts_event_workaround enabled
[ 1.474188] fe201000.serial: ttyAMA0 at MMIO 0xfe201000 (irq = 21, base_baud = 0) is a PL011 rev2
[ 1.481070] bcm2835-power bcm2835-power: Broadcom BCM2835 power domains driver
[ 1.482077] mmc-bcm2835 fe300000.mmcnr: mmc_debug:0 mmc_debug2:0
[ 1.482105] mmc-bcm2835 fe300000.mmcnr: DMA channel allocated
[ 1.511548] of_cfs_init
[ 1.511724] of_cfs_init: OK
[ 1.526733] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
[ 1.528416] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.530096] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.533094] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
[ 1.534776] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
[ 1.546368] mmc0: SDHCI controller on fe340000.mmc [fe340000.mmc] using ADMA
[ 1.547131] Waiting for root device PARTUUID=f3713887-02…
[ 1.600129] mmc1: new high speed SDIO card at address 0001
[ 1.649167] mmc0: new ultra high speed DDR50 SDHC card at address aaaa
[ 1.650140] mmcblk0: mmc0:aaaa WX32G 29.7 GiB
[ 1.652525] mmcblk0: p1 p2
[ 1.657759] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 1.667346] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[ 1.667455] VFS: Mounted root (ext4 filesystem) readonly on device 179:2.
[ 1.668257] devtmpfs: mounted
[ 1.677917] Freeing unused kernel memory: 3712K
[ 1.679225] usb 2-2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 8.01
[ 1.679259] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 1.679284] usb 2-2: Product: JMicron
[ 1.679305] usb 2-2: Manufacturer: JMicron
[ 1.679326] usb 2-2: SerialNumber: 000000004ACA
[ 1.682504] usb 2-2: UAS is ignored for this device, using usb-storage instead
[ 1.682631] usb 2-2: UAS is ignored for this device, using usb-storage instead
[ 1.682660] usb-storage 2-2:1.0: USB Mass Storage device detected
[ 1.683255] usb-storage 2-2:1.0: Quirks match for vid 152d pid 0578: 1800000
[ 1.683453] scsi host0: usb-storage 2-2:1.0
[ 1.689520] Run /sbin/init as init process
[ 1.689544] with arguments:
[ 1.689554] /sbin/init
[ 1.689563] with environment:
[ 1.689573] HOME=/
[ 1.689583] TERM=linux
[ 1.805417] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 1.956067] usb 1-1: New USB device found, idVendor=2109, idProduct=3431, bcdDevice= 4.21
[ 1.956115] usb 1-1: New USB device strings: Mfr=0, Product=1, SerialNumber=0
[ 1.956139] usb 1-1: Product: USB2.0 Hub
[ 1.957769] hub 1-1:1.0: USB hub found
[ 1.958093] hub 1-1:1.0: 4 ports detected
[ 2.061804] systemd[1]: System time before build time, advancing clock.
[ 2.143793] NET: Registered protocol family 10
[ 2.145555] Segment Routing with IPv6
[ 2.203703] systemd[1]: systemd 241 running in system mode. (+PAM +AUDIT +SELINUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD -IDN2 +IDN -PCRE2 default-hierarchy=hybrid)
[ 2.204431] systemd[1]: Detected architecture arm64.
[ 2.238996] systemd[1]: Set hostname to .
[ 2.686232] scsi 0:0:0:0: Direct-Access JMicron 0801 PQ: 0 ANSI: 6
[ 2.687798] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 2.688653] sd 0:0:0:0: [sda] Write Protect is off
[ 2.688687] sd 0:0:0:0: [sda] Mode Sense: 47 00 00 08
[ 2.689403] sd 0:0:0:0: [sda] Disabling FUA
[ 2.689434] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 2.716986] sda: sda1
[ 2.720194] sd 0:0:0:0: [sda] Attached SCSI disk
[ 2.757505] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.763630] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.764421] systemd[1]: Listening on udev Control Socket.
[ 2.765236] random: systemd: uninitialized urandom read (16 bytes read)
[ 2.765674] systemd[1]: Listening on initctl Compatibility Named Pipe.
[ 2.766698] systemd[1]: Listening on Journal Socket (/dev/log).
[ 2.771116] systemd[1]: Created slice system-systemd\x2dfsck.slice.
[ 2.772240] systemd[1]: Listening on fsck to fsckd communication Socket.
[ 2.773072] systemd[1]: Listening on udev Kernel Socket.
[ 2.774531] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.873530] cryptd: max_cpu_qlen set to 1000
[ 3.321150] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[ 3.390592] systemd-journald[133]: Received request to flush runtime journal from PID 1
[ 3.815672] rpivid-mem feb00000.hevc-decoder: rpivid-hevcmem initialised: Registers at 0xfeb00000 length 0x00010000
[ 3.817325] rpivid-mem feb10000.rpivid-local-intc: rpivid-intcmem initialised: Registers at 0xfeb10000 length 0x00001000
[ 3.820554] rpivid-mem feb20000.h264-decoder: rpivid-h264mem initialised: Registers at 0xfeb20000 length 0x00010000
[ 3.822606] rpivid-mem feb30000.vp9-decoder: rpivid-vp9mem initialised: Registers at 0xfeb30000 length 0x00010000
[ 3.880531] snd_bcm2835: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.887025] bcm2835_audio bcm2835_audio: card created with 8 channels
[ 3.891315] vc_sm_cma: module is from the staging directory, the quality is unknown, you have been warned.
[ 3.893190] bcm2835_vc_sm_cma_probe: Videocore shared memory driver
[ 3.893218] [vc_sm_connected_init]: start
[ 3.900779] [vc_sm_connected_init]: installed successfully
[ 3.910385] mc: Linux media interface: v0.10
[ 3.945418] videodev: Linux video capture interface: v2.00
[ 4.009207] bcm2835_mmal_vchiq: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.056046] bcm2835_codec: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.056067] bcm2835_v4l2: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.057610] bcm2835_isp: module is from the staging directory, the quality is unknown, you have been warned.
[ 4.063308] bcm2835-codec bcm2835-codec: Device registered as /dev/video10
[ 4.063361] bcm2835-codec bcm2835-codec: Loaded V4L2 decode
[ 4.072983] bcm2835-codec bcm2835-codec: Device registered as /dev/video11
[ 4.073029] bcm2835-codec bcm2835-codec: Loaded V4L2 encode
[ 4.079032] bcm2835-isp bcm2835-isp: Device node output[0] registered as /dev/video13
[ 4.079636] bcm2835-isp bcm2835-isp: Device node capture[0] registered as /dev/video14
[ 4.080186] bcm2835-codec bcm2835-codec: Device registered as /dev/video12
[ 4.080233] bcm2835-codec bcm2835-codec: Loaded V4L2 isp
[ 4.080253] bcm2835-isp bcm2835-isp: Device node capture[1] registered as /dev/video15
[ 4.080824] bcm2835-isp bcm2835-isp: Device node stats[2] registered as /dev/video16
[ 4.080855] bcm2835-isp bcm2835-isp: Register output node 0 with media controller
[ 4.080875] bcm2835-isp bcm2835-isp: Register capture node 1 with media controller
[ 4.080901] bcm2835-isp bcm2835-isp: Register capture node 2 with media controller
[ 4.080918] bcm2835-isp bcm2835-isp: Register capture node 3 with media controller
[ 4.081142] bcm2835-isp bcm2835-isp: Loaded V4L2 bcm2835-isp
[ 4.085910] bcm2835-codec bcm2835-codec: Device registered as /dev/video18
[ 4.085966] bcm2835-codec bcm2835-codec: Loaded V4L2 image_fx
[ 4.204845] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 4.220703] [drm] Initialized v3d 1.0.0 20180419 for fec00000.v3d on minor 0
[ 4.303833] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 4.378985] cfg80211: Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 4.392412] [drm] No displays found. Consider forcing hotplug if HDMI is attached
[ 4.392506] vc4-drm gpu: bound fe600000.firmwarekms (ops vc4_fkms_ops [vc4])
[ 4.393195] [drm] Initialized vc4 0.0.0 20140616 for gpu on minor 1
[ 4.458030] brcmfmac: F1 signature read @0x18000000=0x15264345
[ 4.477651] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.480235] usbcore: registered new interface driver brcmfmac
[ 4.726907] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.727044] brcmfmac: brcmf_fw_alloc_request: using brcm/brcmfmac43455-sdio for chip BCM4345/6
[ 4.736197] brcmfmac: brcmf_c_preinit_dcmds: Firmware: BCM4345/6 wl0: Jan 4 2021 19:56:29 version 7.45.229 (617f1f5 CY) FWID 01-2dbd9d2e
[ 6.570971] uart-pl011 fe201000.serial: no DMA platform data
[ 6.599288] random: crng init done
[ 6.599313] random: 7 urandom warning(s) missed due to ratelimiting
[ 6.654139] 8021q: 802.1Q VLAN Support v1.8
[ 6.953885] brcmfmac: brcmf_cfg80211_set_power_mgmt: power save enabled
[ 7.114822] bcmgenet fd580000.ethernet: configuring instance for external RGMII (RX delay)
[ 7.115063] bcmgenet fd580000.ethernet eth0: Link is Down
[ 8.131379] xhci_hcd 0000:01:00.0: remove, state 1
[ 8.131401] usb usb2: USB disconnect, device number 1
[ 8.131410] usb 2-2: USB disconnect, device number 2
[ 8.132750] sd 0:0:0:0: [sda] Synchronizing SCSI cache
[ 8.133488] sd 0:0:0:0: [sda] Synchronize Cache(10) failed: Result: hostbyte=0x01 driverbyte=0x00
[ 8.203315] xhci_hcd 0000:01:00.0: USB bus 2 deregistered
[ 8.203378] xhci_hcd 0000:01:00.0: remove, state 4
[ 8.203392] usb usb1: USB disconnect, device number 1
[ 8.203400] usb 1-1: USB disconnect, device number 2
[ 8.204947] xhci_hcd 0000:01:00.0: USB bus 1 deregistered
[ 8.233504] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 8.233539] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 1
[ 8.233935] xhci_hcd 0000:01:00.0: hcc params 0x002841eb hci version 0x100 quirks 0x0000060000000890
[ 8.234561] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 5.10
[ 8.234568] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.234573] usb usb1: Product: xHCI Host Controller
[ 8.234578] usb usb1: Manufacturer: Linux 5.10.63-v8+ xhci-hcd
[ 8.234583] usb usb1: SerialNumber: 0000:01:00.0
[ 8.234963] hub 1-0:1.0: USB hub found
[ 8.235024] hub 1-0:1.0: 1 port detected
[ 8.235399] xhci_hcd 0000:01:00.0: xHCI Host Controller
[ 8.235410] xhci_hcd 0000:01:00.0: new USB bus registered, assigned bus number 2
[ 8.235422] xhci_hcd 0000:01:00.0: Host supports USB 3.0 SuperSpeed
[ 8.235638] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 5.10
[ 8.235646] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 8.235652] usb usb2: Product: xHCI Host Controller
[ 8.235657] usb usb2: Manufacturer: Linux 5.10.63-v8+ xhci-hcd
[ 8.235662] usb usb2: SerialNumber: 0000:01:00.0
[ 8.236198] hub 2-0:1.0: USB hub found
[ 8.236252] hub 2-0:1.0: 4 ports detected
[ 8.385670] usb 2-2: new SuperSpeed Gen 1 USB device number 2 using xhci_hcd
[ 8.406911] usb 2-2: New USB device found, idVendor=152d, idProduct=0578, bcdDevice= 8.01
[ 8.406924] usb 2-2: New USB device strings: Mfr=1, Product=2, SerialNumber=3
[ 8.406930] usb 2-2: Product: JMicron
[ 8.406935] usb 2-2: Manufacturer: JMicron
[ 8.406940] usb 2-2: SerialNumber: 000000004ACA
[ 8.409517] usb 2-2: UAS is ignored for this device, using usb-storage instead
[ 8.409570] usb 2-2: UAS is ignored for this device, using usb-storage instead
[ 8.409578] usb-storage 2-2:1.0: USB Mass Storage device detected
[ 8.410075] usb-storage 2-2:1.0: Quirks match for vid 152d pid 0578: 1800000
[ 8.410192] scsi host0: usb-storage 2-2:1.0
[ 8.533377] usb 1-1: new high-speed USB device number 2 using xhci_hcd
[ 8.661558] usb 1-1: device descriptor read/64, error -71
[ 8.897549] usb 1-1: device descriptor read/64, error -71
[ 9.133375] usb 1-1: new high-speed USB device number 3 using xhci_hcd
[ 9.265575] usb 1-1: device descriptor read/64, error -71
[ 9.437888] scsi 0:0:0:0: Direct-Access JMicron 0801 PQ: 0 ANSI: 6
[ 9.438203] sd 0:0:0:0: Attached scsi generic sg0 type 0
[ 9.438473] sd 0:0:0:0: [sda] 1953525168 512-byte logical blocks: (1.00 TB/932 GiB)
[ 9.439030] sd 0:0:0:0: [sda] Write Protect is off
[ 9.439038] sd 0:0:0:0: [sda] Mode Sense: 47 00 00 08
[ 9.439639] sd 0:0:0:0: [sda] Disabling FUA
[ 9.439648] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn’t support DPO or FUA
[ 9.458187] sda: sda1
[ 9.460157] sd 0:0:0:0: [sda] Attached SCSI disk
[ 9.501588] usb 1-1: device descriptor read/64, error -71
[ 9.609542] usb usb1-port1: attempt power cycle
[ 10.021359] usb 1-1: new high-speed USB device number 4 using xhci_hcd
[ 10.629266] xhci_hcd 0000:01:00.0: Setup ERROR: setup address command for slot 2.
[ 10.701861] EXT4-fs (sda1): mounted filesystem with ordered data mode. Opts: (null)
[ 10.833471] xhci_hcd 0000:01:00.0: Setup ERROR: setup address command for slot 2.
[ 11.041361] usb 1-1: device not accepting address 4, error -22
[ 11.169370] usb 1-1: new high-speed USB device number 5 using xhci_hcd
[ 11.169462] xhci_hcd 0000:01:00.0: Setup ERROR: setup address command for slot 2.
[ 11.197522] bcmgenet fd580000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[ 11.197554] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[ 11.377474] xhci_hcd 0000:01:00.0: Setup ERROR: setup address command for slot 2.
[ 11.585367] usb 1-1: device not accepting address 5, error -22
[ 11.585607] usb usb1-port1: unable to enumerate USB device
[ 11.869372] Adding 4194300k swap on /swap/swapfile. Priority:-2 extents:13 across:28147712k FS
[ 12.804465] ICMPv6: process `dhcpcd’ is using deprecated sysctl (syscall) net.ipv6.neigh.eth0.retrans_time - use net.ipv6.neigh.eth0.retrans_time_ms instead
[ 13.435510] Bluetooth: Core ver 2.22
[ 13.435598] NET: Registered protocol family 31
[ 13.435604] Bluetooth: HCI device and connection manager initialized
[ 13.435619] Bluetooth: HCI socket layer initialized
[ 13.435627] Bluetooth: L2CAP socket layer initialized
[ 13.435641] Bluetooth: SCO socket layer initialized
[ 13.442652] Bluetooth: HCI UART driver ver 2.3
[ 13.442663] Bluetooth: HCI UART protocol H4 registered
[ 13.442724] Bluetooth: HCI UART protocol Three-wire (H5) registered
[ 13.442869] Bluetooth: HCI UART protocol Broadcom registered
[ 13.628407] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
[ 13.628418] Bluetooth: BNEP filters: protocol multicast
[ 13.628432] Bluetooth: BNEP socket layer initialized
[ 19.326627] bridge: filtering via arp/ip/ip6tables is no longer available by default. Update your scripts to load br_netfilter if you need this.
[ 19.330121] Bridge firewalling registered
