If I do a fresh install of Umbrel now, is it better to install the latest from GitHub or can I install version 15 beta 2 directly?
Hi, currently flashing straight to beta 1.5-2 has an issue where it only recognizes 400mb of your storage device. If you want to run the latest beta, try flashing the current main version then opt into the beta in the Settings page.
Hello, thanks for the response, I had installed the beta before reading the post and it did do what you mentioned, but I expanded the capacity with gparted and for now it has been working perfectly for a few hours.
