Docker interfering with Umbrel
Had to restart Umbrel as the apps were no longer responsive.
Upon running the following command…
sudo ~/umbrel/scripts/start
I get…
network umbrel_main_network was found but has incorrect label com.docker.compose.network set to "umbrel_main_network"
Any tips on how best to resolve this?
Running:
  • Docker version 24.0.5 / Docker compose v2.23.0
  • Umbrel 0.5.4
  • Ubuntu 22.10
Only way I found to resolve this, was to reinstall docker, copy the .env file and then…
Step 1 - stop Umbrel node with:
cd umbrel
sudo ./scripts/stop
Step 2 - clean / reconfigure the broken container:
sudo rm .env && sudo ./scripts/configure
Step 3 - Restart node:
sudo ./scripts/start
