Dennys Umbrel App Store ☂️
Added Homey.
Hey @denny
I have troubles adding an AI Agent to my Sparky Fitness Instance. When I try to add the local Llama (hosted on my Umbrel) I receive the following error:
Authentication: No token, active session, or valid API key provided.
Not sure what the issue is as an API key is not required and I tried all possible urls e.g. localhost, Umbrel.local, and IP. Is there a chance that is a network issue in how the docker container is built?
Oh and this Note also pops up:
Note: If you encounter an "Invalid key length" error, ensure your encryption and JWT authentication keys in the server's env variables are 64 hex.
Cheers
Thank you Denny! Register new user is now working and app too :folded_hands:t3:
Hey @ackerland!
I found the issue and updated the setup.
The problem was the JWT_SECRET: it must be 64 hex characters, but it was previously a Base64 value. This can break Sparky’s auth layer and lead to errors like “Authentication: No token, active session, or valid API key provided”.
I’ve fixed this and also updated to version 0.16.1.
I hope this resolves the issue. Please try adding the local Llama / AI agent again and let me know if it works now :+1:
Thanks a lot for reporting this! :flexed_biceps:
Added Wastebin.
Added FilePizza.
Hi Denny,
Would it be possible to add slskd to your app store? It’s on Docker Hub but I don’t know how to go from that to getting it on Umbrel.
Hey @ne.dekuji!
Good news: slskd is already available in my app store and has been there for quite a while now.
You can find it in the media category. :flexed_biceps:
Added Super Mario War. (Because why not. :smiling_face_with_sunglasses:)
(Apparently I’m blind - I looked but didn’t see it). Amazing! Thanks.
Added Infisical.
Added LubeLogger. (App No. 300 :partying_face:)
Hi @Denny! Can you take a look at Wealthfolio and see if it’s possible to add it on Umbrel? Thanks a lot!
Hi @denny , how do updates work with your repo? I noticed the version of Scrypted is quite old. Does it not pull updates with he latest release? Thank you
Good morning! Is there a way to implement SimpleX chat in UmbrelOS?
Well SimpleX Chat provides Docker Containers … so, it should be possible but is one of these features what you want?
Hi Rod, I was reading that you can run a SMP server and point your app to it, is it right?
Anyone heard from Denny in a while? I tried sending him a message a few weeks ago and had no reply but its been read. I tipped him some BTC via LN link on his Github but it seems it failed but sats did leave my wallet. Wanted to make sure they made their way to him.
Hope that @denny response … his last update on his Community App Store was 2 months ago!
Hi, can you please add Postiz, there is no other social media management tool in the store so i think it’s needed
