@oconical Thanks for the suggestion! Cloud Commander is now in the Store. Enjoy! ![]()
Added Cloud Commander.
I think there is a small configuration issue:
volumes:
- ${APP_DATA_DIR}/data:/root
- /:/mnt/fs
Because currently, the real file path / is located on /mnt/fs in the software and the container root for the docker is showing as /
I don’t know if its a docker setting and probably a javascript code issue in rendering it.
But we could change it so it will make sense to some that worked with android or other systems that mount an external file system in a container.
volumes:
- /root:/root
- /:/srv
so that the OS Umbrel is running on is mounted at the server ( /srv) folder.
I think the line - ~:/root in the original file was just a pointer for user home. So it has a path to .bashrc and other files used in terminal.
I think there is a few quirks to the program. But this is a giant step towards loading an alternative to webmin or filemin.
Hey @oconical! Thanks for the tip! I’ve updated the volume mounts so the host root is now under /srv and the home directory is properly mounted.
Hey @robinwill!
Thank you for your suggestion. I really appreciate it. Cal.com is now on my agenda. ![]()
One Year of Bugs, Coffee, and Community Love![]()
Hard to believe, but exactly one year ago today, on 09/18/2024, I launched this Community App Store. Back then, I honestly had no clue about Docker or yml files, and image editing was completely new to me. Over the past 12 months, I’ve learned everything step by step, tried a lot, made plenty of mistakes, and learned from them.
By now, over 250 apps have been added to the store, I’ve made more than 6,400 commits on GitHub, and created over 1,300 assets like icons and screenshots. Almost 50 apps have even made it into the official Umbrel repository. Every app, every commit, and every asset has been an adventure of its own. Some ran perfectly from the start, others kept me sipping coffee for hours while I hunted down bugs.
For the time being, I won’t be adding any new apps myself, as I just don’t have the time ![]()
. But I’m more than happy to take suggestions from the community and try to integrate them. I’d also appreciate it if you let me know about updates to existing apps, so the store stays up to date.
A huge thank you to everyone using the store, giving feedback, or just checking it out. Without you, none of this would be nearly as exciting.
Cheers, Umbrel Community! ![]()
Congrats!
Hey @denny . Whats the chances you can get another mining pool to work correctly? Maybe like yiimp or miningcore? I tried buy i just dont have the skill loo
Hi @denny . Appreciate all your hard work here! Is there any chance you could add Unifi UISP? They got rid of their free cloud instances but there is a docker version available. Would love to see it on Umbrel!
He has one in the store
how about UNraid
docker pull rdnelson/unraid:6.12.13
He has the Unifi controller which is not the same as the UISP controller
I think I know what you talking about. It used to be called UNMS
docker UISP,
that would be this docker container:
which is the docker version of this software that is normally installed on a Linux server:
https://help.uisp.com/hc/en-us/articles/22591008678039-UISP-First-Time-Setup-Installation
@denny should be able to bring that over to his store
Hi Denny,
Thank you again for your immense contribution to this community!
Crafty Controller has received an update (4.5.4) do you think you can update the app in your store?
Have a good day and thank you again!
The link of the new version:
Hey @GrouxCL, thanks for the heads-up! ![]()
Crafty Controller has been updated to v4.5.4. All done! ![]()
To all users from the UK ![]()
I’ve moved all app assets from Imgur to GitHub because of Imgur restrictions in your region. All assets should now be visible again!
If you still notice any missing icons, screenshots or broken links, please let me know. Thanks a lot for your support! ![]()
Added ThinkDashboard.
