(post deleted by author)
Added Speedtest Tracker.
Added LiteChat.
Added NeonLink.
Really silly ask, perhaps, but I can’t seem to find the answer… how do I add this / start to use this?
Hey @Mackenzie! ![]()
Not silly at all!
Here’s a helpful tutorial video that shows how to get started. Just follow it, and you’ll be up and running in no time!
https://github.com/dennysubke/dennys-umbrel-app-store
Added Wally.
Added Termix.
Added Dawarich.
Sad that you have this oppinion. People can trade Bitcoin against fiat to gain more bitcoin with Hummingbot i dont know why anyone would be against it.
I understand your point, and yes, technically Hummingbot could be used to trade Bitcoin against fiat to gain more Bitcoin. The reason I’m cautious is more about philosophy than functionality. I prefer to keep my Umbrel App Store aligned with my values as a Bitcoin-only supporter and avoid apps focused on trading or altcoins.
I really appreciate your suggestion, and I hope you understand my perspective
. I’m always happy to consider other ideas that fit the Bitcoin-first approach.
Added Haus.
Hi Denny,
Can you add Frappe apps? (Frappe: Open Source Software)
Especially Web Development Framework | Frappe Framework
TIA
Hi @tveshaj!
Frappe looks interesting! I’ll check what dependencies it needs (DB, Redis, workers, etc.) to see if it fits Umbrel. If you have specific Frappe apps in mind (like ERPNext), let me know.
Added ownCloud.
Added Sync-in.
Added CheckCle.
Added Docspell.
Added Reitti.
Denny would you consider adding GitHub - Bitcoin-II/BitcoinII-Core: BitcoinII Source Code Repository ?
Would it be possible/easy to add it using the already available Umbrel bitcoin core app with the BitcoinII back end?
