Dennys Umbrel App Store ☂️
Hello @denny, there’s a new version of Yamtrack with some new features. It would be great if we could have an update. Thanks for the great work!
Hey @jumpcoins
Thanks for the heads-up about the update! The app has been updated to version 0.24.4. :flexed_biceps:
Added FileBrowser Quantum.
Added Brave.
Added Palmr.
Added Teable.
Added Haptic.
Added Komodo. (App No. 200 :partying_face:)
Added Kurpod.
Hey denny, one small tweak to the wger app. Adding
ports:
- “8815:80”
Under the web service opens up a port to be connected to via the wger mobile app. In my case I chose 8815
Thanks so much for your work on all of this. Incredible!
Hey @rnutstink, thanks for the tip and your kind words - really appreciate it.
The wger app is still listed as In Progress, which means I am actively working on getting it properly integrated into Umbrel. Unfortunately, wger is currently causing some other issues, but I am working on a solution.
As soon as the app is fully integrated and stable, I will post an update here in the forum. Thanks again for your support. :flexed_biceps:
Added Group Office.
Added Ticky.
Wonderful Repo! Would love if you can take a look at https://ente.io
Added Tududi.
Added Zen.
Added Invoicerr.
Hummingbot tradebot software maybe?
Hello Denny,
I have a question for you. I’m curious to know how you update the apps on your community app store? Is it something you do manually when you know there is a new version of an app out or you have some kind of script running after X days checking for updates? I’m asking because I’m a big fan of the app Yamtrack and there are 2 new updates since your last post. I don’t want to be pushy so If I knew that it’s something that gets refreshed like every 2 weeks or every month, then I’ll wait patiently for those updates :wink: Thanks again for your great work.
Hey @jumpcoins!
Thanks a lot for your kind message and feedback. I really appreciate it :blush:
Just to clarify, I run the community app store completely on my own and I only do it for fun. Because of that, I rely on help from the community when it comes to spotting updates. Unfortunately, that is the only way I can keep everything up to date. All updates are done manually within a local Docker Compose setup where I test each app before pushing changes to the store.
I have just updated Yamtrack to the latest version (v0.24.6). Thanks again for pointing it out. If you would like, I can also submit a pull request to add the app to the official Umbrel App Store since it is not available there yet.
Always happy to hear from users like you. Your feedback really helps keep everything going smoothly :raising_hands:
