Deleted network mount not unmounting
Massive uber thanks with loads of hugs and kisses!! I’m back in, and everything is working.
That recovery folder, do I need to keep it or can I deleted it after a few weeks if everything works fine?
Finally you mentioned that there is a problem with RPi4 and the boot script. So should I simply way for it to be resolved in the next update?
