How do I clear my lightning transactions from umbrel? I’ve made so many transactions that it is now so slow to use the dashboard.
Why do you need to use dashboard as wallet?
BTW, the node wallet should NOT be used as your main regular wallet, as I explained in these Umbrel guides:
- Getting started with Umbrel - see the section in General rules bout “managing funds”
Be your own bank - Think like a bank
Are so many apps already for / in Umbrel to use in a nice fashion manner.
RTL, Thunderhub, Zeus, Zap, Electrum, Sparrow, Specter etc - all explained in the Getting started with Umbrel section “connect wallets”.
The main Umbrel dashboard is just for managing the apps, making backup of your LN channels, managing node settings, troubleshooting, generate new onchain deposit address.
Thanks for the advice but for now is it possible to purge my previous LN transaction? I have made over 2500 LN payments and would like to clear it from umbrel as it’s slowing down the dashboard.
no, those logs will stay forever.
Or start a new node instance
Edit your lnd.conf file and add at the end of [Application] section these lines:
# Mark unpayable, unpaid invoices as deleted
gc-canceled-invoices-on-startup=1
gc-canceled-invoices-on-the-fly=1
# Avoid historical graph data sync
ignore-historical-gossip-filters=1
# Avoid slow startup time
sync-freelist=1
# Avoid high startup overhead
stagger-initial-reconnect=1
Then restart lnd service
cd ~/umbrel && docker-compose restart lnd
All those unpaid invoices will be gone
More details on lnd.conf example here
nope. all executed invoices, txs, will remain there.
So the only way is to start a fresh node, new seed open new channels?
yes. But really don’t understand why bothers you that much, are just a bunch of logs. That’s it
It’s slowing down the dashboard so that’s why I want to clear it.
