Cannot access Umbrell via SSH [Solved]
I recently installed UmbrelOS 1.4.2 on a small PC I had and it seems quite promising.
As I would access to a NAS via Umbrel, I need to connect via SSH and mount the NAS.
However, I cannot figure how to do it. Access is denied when I try “ssh username@umbrel.local” and provide my umbrel password.
Is there some ‘root’ user and password that I would provide? Do I have to activate some function on the UmbrelOS itself in order to allow SSH?
Thank you in advance for your advices.
Regards,
Philippe.
Got it…
The answer is: ssh umbrel@umbrel.local, with the username defined at the installation.
If this can help…
@PhilR thank you for providing the solution too! This helped me.
Once you are in as the Umbrel UID … to get root level authority … you prefix your commands with sudo and provide your Password that you configured at UmbrelOS Setup.
