Hi, I have an Beelink ME with UmbrelOS 1.5 running , 2TB M2 ssd, 16GB ram. My problem is UmbrelOS doesnt see the other m2 ssd drives I have. In bios the other drives show. Is there an app to where UmbrelOS can see the others and I can used them?
Thanks
Maybe I’m wrong, but I had the same issue, and the only way I found was to modify the fstab file, add the second drive there, and then bind the folders I needed with the second drive.
But every time you update the os you lose the configuration and you have to repeat it, not perfect but works if you know what to do
There has to be a better way. Do you know when the next update will be? You finger this would have been done long ago. Realy like this OS but this can be an deal breaker.
