Balance of Satoshis
How Can I install balance of Satoshi in my Umbrel OS Server Device (Umbrel Home)? Where Can I find the Umbrel Terminal in my Umbrel OS Server (Umbrel Home)?
Would you like to use the LndBoss | Umbrel App Store application?
A GUI for BalanceOfSatoshis!
You can also run commands on Umbrel via command prompt/powershell on Windows or terminal on Mac and SSH into your Umbrel via command:
ssh umbrel@umbrel.local
Then you can also you this command for lncli commands as well:
sudo ~/umbrel/scripts/app compose lightning exec lnd lncli <command>
Replace <command> with any of the lncli commands, such as getinfo.
As referenced in the FAQ guide here
LndBoss makes it easy though to access the BOS commands as well!
Thank you for being so helpful !!!
