I am trying to create a backup drive for my Umbrel using this drive, but when I told Umbrel to reformat it to exFAT, it still didn’t accept it (it started out as NTFS). Then, I tried rebooting, but it tried to use the new drive as a new drive. I had to unplug power and grab the drive, then reboot the system. I manually formatted it to ext4 using my Laptop afterwards (I saw that the reformatting to exFAT worked on the Laptop), but that still said it needs reformatting. So, I reformatted it as ext4 on the Umbrel, and it still didn’t do anything.
In the logs, I can see that there were no issues, and lsblk -f on the Umbrel shows it as correctly formatted, but the menu still asks to reformat it.
Nov 09 00:44:33 umbrel umbreld[930]: [files:externalstorage] Formatting device sdb as ext4 with label UmbBackup
Nov 09 00:44:33 umbrel umbreld[930]: [files:externalstorage] Cleaning partition table for device sdb
Nov 09 00:44:37 umbrel umbreld[930]: [files:externalstorage] Removing all filesystem signatures for device sdb
Nov 09 00:44:38 umbrel umbreld[930]: [files:externalstorage] Creating new partition table for device sdb
Nov 09 00:44:38 umbrel umbreld[930]: [files:externalstorage] Waiting for changes for device sdb
Nov 09 00:44:38 umbrel kernel: sdb: sdb1
Nov 09 00:44:39 umbrel kernel: sdb: sdb1
Nov 09 00:44:39 umbrel umbreld[930]: [files:externalstorage] Creating ext4 filesystem for device sdb
Nov 09 00:44:48 umbrel umbreld[930]: [files:externalstorage] Successfully formatted device sdb as ext4 with label UmbBackup
