App not load on browser with external drive
Hi guys
This is my first post i’m glad to be part of this community!
I have an issue so i hope some one can help me.
I have the last version of umbrel running on a minipc with a N100 processor and 8GB of RAM this device have an internal NVME of 128GB and i add a seccond NVME of 512 GB
I mount format and create a symbolic link to the app directory all work ok but i have a strange issue
If i open the browser from umbrel and click on app a get a spin wheel and nothing show.
if i list the directory on terminal all is ok, the apps works ok.
but.. there is no graphical interface to show the app content directory
So..
How can i fix this?
I will try to resume the commands here
65 echo “/dev/disk/by-partuuid/7fd745d3-4c7e-47f7-97cf-440997423acf /mnt/nvme0n1 auto rw,user,auto 0 0” | sudo tee --append /etc/fstab
66 sudo mount /mnt/nvme0n1
67 more /etc/fstab
68 sudo chmod -R 0711 /mnt/nvme0n1
69 sudo chown umbrel /mnt/nvme0n1
70 sudo mount /mnt/nvme0n1
71 systemctl daemon-reload
72 sudo mount /mnt/nvme0n1
73 sudo mv ~/umbrel/app-data /mnt/nvme0n1
74 ls /mnt/nvme0n1
75 sudo ln -s /mnt/nvme0n1/app-data ~/umbrel/
if i list by terminal all is ok
umbrel@umbrel:~/umbrel/app-data$ ls -lha
total 52K
drwxr-xr-x 13 umbrel umbrel 4.0K Oct 3 19:09 .
drwxr-xr-x 4 root root 4.0K Sep 10 14:19 ..
drwxr-xr-x 3 umbrel umbrel 4.0K Sep 26 20:21 adguard-home
drwxr-xr-x 3 umbrel umbrel 4.0K Oct 7 23:12 cloudflared
drwxr-xr-x 4 umbrel umbrel 4.0K Sep 10 14:24 immich
drwxr-xr-x 2 umbrel umbrel 4.0K Oct 3 19:09 neko
drwxr-xr-x 3 umbrel umbrel 4.0K Sep 11 12:06 nginx-proxy-manager
drwxr-xr-x 3 umbrel umbrel 4.0K Oct 7 23:12 ollama
drwxr-xr-x 3 umbrel umbrel 4.0K Sep 10 14:56 open-webui
drwxr-xr-x 4 umbrel umbrel 4.0K Sep 10 14:30 rustdesk-server
drwxr-xr-x 3 umbrel umbrel 4.0K Sep 13 04:38 seafile
drwxr-xr-x 3 umbrel umbrel 4.0K Sep 28 03:57 syncthing
drwxr-xr-x 3 umbrel umbrel 4.0K Oct 7 23:12 tailscale
I miss anything here ?
My umbre version is : 1.4.2
Hope some one can help me here
Br
umbrelOS unfortunately doesn’t support loading apps or storing app data on a secondary storage device currently. As such, it’s very likely that what you did will break when you do an update to your Umbrel.
If I understand correctly your app runs but the app data isn’t browsable from the gui correct? Although it’s not supported, we can try to figure it out if you can give the system logs by going to Settings > Trubleshoot > umbrelOS > download logs.
